Battery power
A project log for Portable UVC LED bar
An array of high powered germicidal LEDs, paired with lithium ion batteries and Arduino controller in a portable footprint.
markcMarkC 04/29/2022 at 20:000 Comments
The final version will have 4 x 18650 Li-ion batteries attached to the rear of the unit. The inside of the bar will be mostly occupied by the array, heatsink, controller, fans, driver, display, and wiring. Placing the batteries externally will avoid cramping other parts and allow enough airflow to keep the array cool.
