The fire alarm is one of those alarms, to immediately protect surroundings from fire. Here we design a simple “Fire Alarm Project” by using a 10K NTC (Negative Temperature Coefficient) thermistor and LM368 Operational Amplifier IC.
This Simple Fire Alarm Project can be used as an indicator or warning circuit for excessive fire and temperature, to connect or disconnect the target device you can connect a relay at the output. Moreover, it prevents the machines and environment from any hazardous or physical harm
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They pride themselves to be your best business partners as well as good friends in every aspect of your PCB needs.
5$ PCB Prototype
Hardware Components
Circuit Diagram
