Pis and Parallel regulators
A project log for Information Batteries - Energy -> Data
Computers render power directly into data, “information batteries”. Data store vs. energy store: more cycling, less materials, costs less.
brian-sutherlandBrian Sutherland 04/30/2022 at 20:320 Comments
The information battery concept might also be modelled with a series of Raspberry Pis equipped with voltage monitoring and larger supercapacitors in series with appropriate balancing, as well as larger solar panels, e.g. 40-100W.
One design feature is parallel voltage regulators, where one regulator charges a small capacitor, e.g. 10,000uF and the other charges a couple of supercapacitors in series e.g. 25F.   The supercapacitors feed back to the small capacitor with a diode, and the computing power load goes across the small capacitor.
For devices where people expect them to turn on instantly like with batteries.  When the sun comes out, the power circuit fills the small bucket (capacitor) quickly to the target voltage to start and run the device, while the larger bucket (supercapacitors) fill more slowly so that when they reach the target voltage, they provide stability from energy transients (like clouds passing) reducing the number of deep sleep cycles required.
 Less time working for investment of CPUs vs more time for greater investment in power stability.
