fusing two filaments into a longer one
A project log for PullStruder: from plastic bottle to PET filament
Ever wanted to use plastic bottle for 3d printing ? Here is how to !
jp-gleyzesJP Gleyzes 05/13/2022 at 19:220 Comments
To achieve this goal I simply used my soldering iron !
I drilled a scrap piece of aluminium at the diameter of the tip of the iron and used it to melt the filament into a PFTE tube.
See this video to better understand !
The white clip to hold the iron in place on its support can be found on my thingiverse's channel here.
