Adding PET into Prusa firmware
A project log for PullStruder: from plastic bottle to PET filament
Ever wanted to use plastic bottle for 3d printing ? Here is how to !
jp-gleyzesJP Gleyzes 07/12/2022 at 07:010 Comments
In order to have default values for PET I have modified the default Prusa firmware.
Here is how I did:
You just have two files to modify. I have just superseeded the "PP" values as I don't use this kind of filament :
and then I made the same here
As you can see the "PET" settings are pointing of the PP_PREHEAT_HOTEND_TEMP. This does the trick!
And I did also modified the original "PET" to "PETG" to avoid confusion...
