Valkyrie High Temp 3d-Printer
A Premium DIY High-Temp 3d Printer
Opensource Premium High Temp DIY FDM 3d-Printer designed by engineering professionals with advanced kinematics for optimal performance and fully automated true bed leveling plus insulated printing chamber and heated integrated drybox for the option to print high temperature materials
Specifications for Designed Size
  • Frame footprint – 500X520X750
  • Print volume – 310X310X300
  • Weight ~45Kg
  • Option to print high-temp materials 300+
Join our Discord Server for all updates
Valkyrie Main Features
  • Advanced Kinematics with independent triple Z axis
    • Fully automated bed leveling
    • Inverted CoreXY for minimal friction
    • XUV Triple Z True Bed Leveling with Maxwell Coupling Criteria
    • Stall-detection homing on all 2+3 – XY+ZUV axis
    • Light tool-head riding on carbon X with MGN9h
    • ABZUV stepper motors all located in the cold zone
  • Temperature Controlled Heated Chamber <80C
    • Engineered insulation options for high level of safety and minimal thermal loss
    • High end ACM Outer Paneling
    • Double glazed window for inside viewing and good insulation
  • Integrated Temperature Controlled Heated Dry-box
    • Filament weight control by load-cell
    • Dry-box temp control <70C
    • Dry-box humidity sensor
  • Advanced Firmware add-ons
    • Chamber temp controls and display
    • Dry-box temp control and display
    • Dry-box humidity display
    • Filament weight display
    • Extruder motor temp sensor and display
  • Water-cooled hotend
    • Option to water-cool extruder stepper motor
General Requirements
Product Choice
The aim is to develop a Premium DIY FDM 3d printer for the DIY 3d printer community
  • Safety features must be very high
  • Engineered advanced Z lift with kinematic coupling
  • Integrated dry-box filament container
  • We want to be able to print high temp materials
  • The project will be open source
  • Size should be scalable < 500
  • Standard alu profiles. 2040 or 3030
  • Belted Z drive
  • Advanced Firmware options
  • Enclosed chamber with engineered insulation for <80C Chamber temp
Function Choices
The machine should have all the functions needed for a trouble-free user experience. The goal is to implement all basic functions plus any feature that is making an advanced high temp premium 3d printer
Competition
  • Ratrig V-Core 3
  • Hevort
  • Voron
  • BLV MGN Cube
  • VZBot
The Development Team
Roy Berntsen – Norway – Lead Engineering Designer
Mark Bridgewater – New Zealand – Mechatronics Design
Cris Lombardi – USA – Firmware, Design and Advanced features
View project log
