FW 3.2.1: Stability Update
A project log for All-In-One Gamma-Ray Spectrometer
More sensitive to gamma radiation than a Geiger counter with the added bonus of telling exactly what's inside your samples!
nuclearphoenixNuclearPhoenix 05/06/2023 at 19:150 Comments
This firmware update should improve overall device stability (random crashes) and fixes an issue with the histogram data output ("set out spectrum") to Gamma MCA. You'll be able to use this output mode now whilst also having the display in "spectrum mode". There should no longer be any issues there.
Other than that, nothing has changed and the dead time is still the same as with the last update that seemingly introduced some of these problems.
https://github.com/OpenGammaProject/Open-Gamma-Detector/tree/main/software
Have fun!
