Battery Sizing
A project log for DIY Solar Bottle Lamp
Solar Bottle Lamp is a solar-powered light that is constructed from waste plastic bottles. The design idea is to reuse waste plastic bottles
open-green-energyOpen Green Energy 06/30/2022 at 18:210 Comments
Earlier I used a 0.5W straw hat LED, but it is not so efficient and the lumens/watt is around 70-80.
So I am planning to replace the LED with a 0.5 Watt cool white SMD LED ( 2835  package). As per the SMD LED datasheet, the forward voltage (Vf) is 3.2V and the luminance is 150 lumens per watt.
My target lumens for the different modes of operation are as follows:
1. Mode-1 ( Low Brightness ): 15 Lumens with a backup time of 24hrs
2. Mode-2 ( Medium Brightness ): 30 Lumens with a backup time of 10 hrs
3. Mode - 3 ( High Brightness): 70 Lumens with a backup time of 5hrs
The power required to drive for the above modes is as follows:
1.  Mode-1:  15/150 = 0.1W
2. Mode-2:  30/150 = 0.2W
3. Mode-3:  70/150 = 0.467W
In the following table, calculations are presented to estimate the battery capacity.  I have considered a 18650 Li-Ion battery (3.7V) with 80% DOD.
Mode Power (W) Current (mA) Energy ( Wh) Driver Efficiency Updated Wh Capacity (mAh) Battery DOD Final Capacity  (mAh)
30.467 145.9 2.335 85% 2.75 742.4 80% 928.1
2 0.2 62.5 2 85% 2.35 635.9 80% 794.9
10.1 31.3 2 85% 2.35 635.9 80% 794.9
Formula Used in the above table:
1. LED Current (mA) = Power (W )/ LED Voltage (3.2V)
2. Energy (Wh) = Power (W) x Backup Time (Hrs)
3. Updated Wh = Wh/ Efficiency
4. Capacity (mAh ) = Updated Wh / Battery Voltage ( 3.7V )
5. Final Capacity =  Capacity / Battery DOD
From the above table, the maximum charge required for the battery is 928.1 mAh. However considering the market availability and taking some additional margin for sunny days, the final battery size selected is 1200 mAh.
