PCB Design
A project log for DIY Solar Bottle Lamp
Solar Bottle Lamp is a solar-powered light that is constructed from waste plastic bottles. The design idea is to reuse waste plastic bottles
open-green-energyOpen Green Energy 05/02/2022 at 18:100 Comments
I have drawn the schematic by using Fusion 360 Electronics Design after that switched to PCB layout. I have placed all the SMD parts on the top side of the PCB and the button on the bottom side of the PCB. The main reason for placing the button switch on the bottom side is that it will be easier to access from outside of the enclosure. It also reduces the PCB board size.
I have ordered my PCB from PCBWay and received it within 7 days.
Download the Gerber files from PCBWay
