Installed the Components in the V2.0 Enclosure
A project log for DIY Solar Bottle Lamp
Solar Bottle Lamp is a solar-powered light that is constructed from waste plastic bottles. The design idea is to reuse waste plastic bottles
open-green-energyOpen Green Energy 05/11/2022 at 18:460 Comments
Installed the PCB and all other external components as I have done in my earlier version. One change is that instead of directly soldering the terminal wires to the PCB, I have used JST PH2.0 connectors.
It will be easier for users and the connection is far better than the direct soldering. There will be no chance of short circuits and loose connections.
