The following is a list of preliminary requirements for the OpenDendrometer:
Type | Requirement |
shall | cost less than $60 in materials |
shall | accommodate tree diameters >=100mm |
shall | be able to be configured as a point dendrometer |
shall | <= 10um linear displacement measurement accuracy, point dendrometer |
shall | range of up to 12mm, point dendrometer |
should | be able to be configured as a circumferential dendrometer |
should | <= 0.025mm diameter change measurement accuracy, circumferential dendrometer |
should | be able to be configured as a fruit dendrometer |
should | <= 0.1mm diameter change measurement accuracy, fruit dendrometer |
should | be human tamper proof |
should | be wildlife tamper proof |
shall | log length measurement twice an hour |
shall | be capable of measuring both expansion and contraction |
shall | alert the user when battery charge is low |
shall | transfer data via Bluetooth |
shall | be contained in a weatherproof enclosure |
shall | operate within temperature range 0 to 55°C |
should | operate within temperature range -20 to 55°C |
