A brief look at the pager
A project log for Resurrecting a '90s tone pager with a GSM module
My mission: to turn a 1990s pager into a 2020s pager, with a little help from Twilio, a Raspberry Pi, and a GSM module.
James FosseyJames Fossey 05/22/2022 at 10:330 Comments
My Tonecall Duo pager arrived in the post two days ago, and I've eagerly taken it apart to see how easy it might be to replace the paging circuit with a GSM module.
First, a bit about the pager itself - it was sold (or, more accurately, leased) on the UK Vodapage network. This was one of four wide-area paging networks that operated in the UK in the heyday of paging (1990s). This particular pager was made in 1994, and is in excellent condition. Assuming the original owner kept the number active, it would have been usable until March 2018, when Vodafone shut down their paging network.
The pager powers on and beeps (extremely loudly). It has a built-in clock, but I can't work out how to set the time on it (maybe it was set automatically over the network?)
Dismantling the pager was very easy - I just needed to remove two screws and the back cover then gracefully fell off. Inside, I was thrilled to discover that the paging circuit can simply be unplugged, and the gap left behind is just the right size for a SIM800L GSM module!
The pager with its paging circuit unplugged (note how it simply plugs in to the main board)
The main difficulty will be wiring up the SIM800L module to the beeper and/or vibrator, and generating the right voltage to power the module. For the latter, I aim to use a 3.7V LiPo battery in the existing AA battery holder.
The SIM800L module (red) fits neatly where the paging circuit used to be!
