Arduino-Home-Automation-PCB
Hello friends this time I came up with very useful PCB which is Home Automation PCB.
Yes arduino is widely used in DIY home automation projects. Many of makers used bread board or zero PCB for their project
But as home Automation is used or our home so things must be also looks good and professional.
You don't want to be there loss wires hanging in your house, so this PCB is best solution for home automation project.
Home automation is the automatic control of electronic devices in your home. These devices are connected to the Internet,
Which allows them to be controlled remotely. With home automation, devices can trigger one another so you don’t have to control them manually via an app or voice assistant
You can place HC-05 BT module in the PCB so that you can remotely control the load in your house remotely.
Component Used
- Arduino Nano
- Header pins
- 5V Relay
- Lipo Battery
- Custom PCB
- Screw Terminals
Custom PCB
In this PCB we used Arduino Nano as a micro controller, and we have used 3 5V relays so that we can run AC load on to this PCB.
One HC O5 BT module is also there to provide BT Connectivity.
I have design circuit and PCB ineasy EDA and ordered PCB from JLCPCB.com
JLCPCB.com are the world leader in PCB manufacturing there PCB production rates are very much affordable and they have world class PCB production unit results fast PCB production.
I have provided the link of circuit desgin so that you can modify it as per your need if you need to change any thing.
https://oshwlab.com/sharmaz747/home-automation-pcb
SMT Assembly service of JLCPCB.com is cherry on top now get your PCB fully assembled and save your time and money Select components for your PCB from there Parts Library of 200k+ in-stock components they are offering $30 valued New User coupons & $24 SMT coupons every month $8.00 setup fee, and $0.0017 per joint
Now no need to order components separately for you PCB and get free from stress of soldering them on PCB just try PCB SMT assembly service and get you PCB with components pre assembled and ready for the project
👉 Try PCBA service of JLCPCB.com and save your time and money, get PCB ready for project, 200K+ components in library of JLCPCB.com as well as 3rd party parts to choose from. Assembly will support 10M+ parts from Digikey, mouser
👉 $30 valued New User coupons
👉 $24 SMT coupons every month
For more detials & offers please visit JLCPCB.com
Follow the simple step to get this PCB board. 1 - Download the circuit board Gerber file: https://oshwlab.com/sharmaz747/home-automation-pcb 2 - Create an account using the link below: JLCPCB.com/PCW 3 - visit JLCPCB.com/PCW Add the Gerber file and place the order.
Demo of Home Automation
Home automation works via a network of devices that are connected to the Internet through different communication protocols, i.e Wi-Fi, Bluetooth, ZigBee, and others. Through electronic interfaces,
the devices can be managed remotely through controllers, either a voice assistant like Alexa or Google Assistant or an app. Many of these IoT devices have sensors that monitor changes in motion, temperature, and light so the user can gain information about the device’s surroundings.
To make physical changes to the device, the user triggers actuators, the physical mechanisms like smart light switches,
motorized valves or motors that allows devices to be controlled remotely.1
In this below small demo video I have connected 3 AC load with the PCB and controlling them using android mobile
Mrinnovative
Androiders
Saimon
mbsg99
ElectroBoy
