Example Project 5 - 3x3x3 LED cube
A project log for The Atmega Hearth
Lets imagine a cheap core for all your breadboard µC Projects.
stefan-xpStefan-Xp 08/20/2014 at 23:496 Comments
Inspired by Daves comment below i started a 3x3x3 smd LED (0603 *holy crap*) cube.
I created the circuit according to this website:
http://www.ledstyles.de/index.php/Thread/5912-Cube-3x3x3-leicht-gemacht-mit-Fotos-und-Schaltpl%C3%A4nen/
The Software was taken from this page (Many Thanks to DaveDarko):
https://gist.github.com/davedarko/62b2d3f6584ba7f11fdf
I didn't check out the SW until now, but it works realy nice :-) I like it!
But at first i found some distraction by soldering the LED Cube ... about 3h.
Please take a look at my video. I will add a better one soon.
Remarks: At the moment the cube is driven by the Arduino uno board ... i forgot my trusty AVRISP MKII at an other place :-/
Result: I'm not the best person to solder LED-Cubes... I think without further preparation 3x3x3 is my limit :-/
davedarko wrote 08/21/2014 at 08:47 point
Yeah you did it! that looks great! I used 2mm thick copper wire for the frame and it looks terribly off shape :D good to know that software I write will work somewhere else too..
davedarko wrote 08/21/2014 at 11:23 point
you could use your arduino board as an isp programmer ;)
Stefan-Xp wrote 08/21/2014 at 18:07 point
Are you serious? 2mm Copper Wire? :-D
I used 0.5mm...
BTW: Did your HW do the same things?
davedarko wrote 08/21/2014 at 18:30 point
It seems that we have the same layer configuration - could have been upside down in this 50-50 chance :)
http://instagram.com/deefdarko - i can't link directly to the video, at least it is broken then - it's the fifth entry... and here is a pic of how serious I am about the 2mm ;) http://instagram.com/p/rtyqGesYoR/ but hey, it's a recycled trash built... those LEDs came from a pcb and I had nothing else. They aren't straightened either. I tried not to overkill and just make something that works.
So any chance you thought about new animations? I saw a waving plane once, that looked cool.
Stefan-Xp wrote 08/21/2014 at 19:57 point
The Layers where changed by me to show the pyramid upright ;-)
Its cool, i like your build!
I will add a ne project log soon :)
davedarko wrote 08/21/2014 at 20:01 point
clever guy! yeah, when a pyramid is upside down, something must be wrong :D
