Initally, I had mounted the heated nozzle to the chassis with a 3D printed component. Since the nozzle only reached temperatures of 210deg and the printed component was made from PETG, I assumed this would be fine. I was wrong.
[Figure 1: Extruder blocked melted]
Fortunately, I had some extrusion pieces lying around that I could use to mount the nozzle. If you want to watch a video of me cutting the extrusion piece, see below!
[Figure 2: Cutting extrusion in Kigali]
