Description;
Hello everyone! In this article, we will talk about the aluminum Power Supply Current Limiter PCB we designed for our electric vehicle YTR08C by YTU Racing in the Formula Student competition, the world's most prestigious undergraduate engineering competition, attended by university students from all over the world who are interested in motor racing.
Details;
This design is sponsored by JLCPCB. This article was brought to you by JLCPCB that is experienced, and do its job fast with high quality. You can order PCBs in any shape, up to 14 layers with awesome quality for a very low price with great customer service and they only arrived few days-3 days-after order!
With 16-year PCB manufacturing experience, JLCPCB also establishes a well-trained engineer&customer support team devoted to ensuring PCBA assembly service faster and cheaper, to ensure assemble your PCB in best service.
Thousands of components supported by JLCPCB and its reliable component partners, like DigiKey and Mouser. This benefits customers to source components much faster and easier, bringing you a shorter PCBA production time.
JLC PCB also performs Visual Inspection, X Ray, Solder Paste Inspection (SPI) controls. Detects if there is any bad solder paste printing. X-ray is used to check the quality of the solder joints (such as BGA) under the components on the line to ensure that the circuit board can achieve 100% test coverage.
https://jlcpcb.com/smt-assembly
Soldering options are also available.
JLC Soldering Types:
Hand-soldering
Reflow Soldering
Wave Soldering
About the Power Supply Current Limiter PCB:
Our team has a fixed 29A power supply to charge the low voltoge battery of the Combustion racing car. To charge the battery at lower current, we designed a current limiting circuit with the support of JLC PCB.
The voltage spent on the resistors works with the feedback system to the input of the opamp. The current you are limiting passes through the mosfets. Mosfets get very hot because the amount of current passing is too much. We recommend using a large heatsink.
How to order PCB at JLCPCB;
This design is sponsored by JLCPCB. After designing the circuit however you want, you can order your PCB and get it to your hand in a short time! We would like to thank JLCPCB for their support and we are very satisfied with the service we received. First, you have to export GERBER and NC files of your PCB files. JLCPCB explained how to do it you can visit the website. They communicate very quickly in the format of the PCB gerber file or in case determination that may cause any problems in terms of production and they deliver the PCB without any problems.
https://support.jlcpcb.com/article/42-how-to-export-altium-pcb-to-gerber-files
After that put the files into single rar file then get to the order page
You are even able to change PCB color for free.
You can change the shipping method. JLCPCB ensures the delivery PCB to your hand for 3 days!
You can check the website of JLCPCB. We want to thank again to JLCPCB for the great quality of its service. Thank you, JLCPCB !
aysenurkarga
PUTMotorsport
mbsg99
