abc-flat-profiles-plate.FCStdThis FreeCAD file is extremely WIP, but I'm posting it here anyway. The default build requires cutting the following parts:- 1.5 mm metal: SwitchPlate, TopPanel, BottomPanel, JackPanel, 3× Spacer, 3× Retainer - 3 mm transparent material: TopPanel_Acrylic - (optional) adhesive foam: BottomFoam The Spacer and Retainer are also available in _Choc variants if you wish to use Kailh Choc low-profile switches (instead of Cherry MX-style switches). fcstd - 572.30 kB - 05/20/2022 at 09:33 |
