This project is run by an Arduino connected to a CRT TV. The potentiometers on the neck control the notes played which are displayed on the TV and picked up by a coil pick.
Components
1×
Arduino UNO or MEGA
I used an Arduino UNO but a MEGA would be even better
1×
CRT Television
Preferably one that is small, Mine was 5 inches and I got it off etsy. Ebay is also a great place to look
2×
SoftPot Membrane Potentiometers
I got the 200mm from sparkfun.com. These will be the strings
1×
Video RCA Cord or Adapter
You can cut one up and solder it or get an adapter that connects to jumper wires
1×
Ukulele Neck
You can also use guitar neck or just 3d print one
