Battery
Configuration is 14 banks with 20 cells. 14s20. Roughly 2kW per pack.
BMS
Goal is to use the Daly Smart BMS with 5A Parallel module & CANBUS Communication.
60A BMS.
https://www.aliexpress.com/item/3256803621810489.html
https://www.aliexpress.com/item/1005002897035148.html
This allows each battery pack to communicate and balance themselves, which seems like a good thing.
Crappack BMS
Same as above, just with a 20A BMS. Cuz it's a crappack.
