weather_station_2_arduino_IDE_code.txt
Please note that my weather station sends data to a home assistant instance on the same network. You may have different requirements so please modify the code to suit your needs.
I've included some comments to help you guys understand it, however i am sharing this code as is with no warranty.
I have not teste any other variant of the ESP32, only the Lolin ESP32 C3-Mini. It will definitely not work with any ESP8266 boards since some pins need to be held high during sleep
plain -
23.30 kB -
08/04/2022 at 10:47
