Make a 14x24 matrix
A project log for Dot flippers
or "flip dotters" if you want. Let's just talk about flip-dot/flip-disc displays and projects using them :-)
muthMuth 02/18/2021 at 13:251 Comment
336 dots give more than 2500 components, I admit it start to be 'not-so-cheap'. Lets solder !
An aluminium plat will make a good support
I used jumpers to link the power and SPI lines between the boards.
Then I played a bit with ESP32 and socket communication over Wifi. I have then a program on a computer that sends video frames packets on this socket.
I've put the kicad and code here : https://github.com/pierre-muth/fast-flipdot
fwacer wrote 03/03/2021 at 16:57 point
Wow that's awesome! I've been checking in on this project from time to time, well done. You were featured in the hackaday email!
