The flipping point
A project log for Dot flippers
or "flip dotters" if you want. Let's just talk about flip-dot/flip-disc displays and projects using them :-)
yann-guidon-ygdesYann Guidon / YGDES 12/21/2016 at 01:200 Comments
So far I have received two kinds of flip-dot panels.
These two have different working points, as measured with a lab power supply:
I'm amazed by the power efficiency of the LUMINATOR array. The printed coil is also more predictible and less subject to corrosion. OTOH the german displays are notably oxydized and several dots are damaged. I expected only one line (out of 19) to be unusable but mishandling might have occured and I can't get the 17 lines I wanted (16 data lines + parity, to spy on the memory).
Conclusion : if I give up on the extra parity line, the LUMINATOR is the best choice for my relay computer project. Thank you @Shaos for your precious help :-)
Now I have to examine the pulse characteristics...
