1Step 1
Print the four parts
Download the STL files from Thingiverse 2129988 and print it with a 3D printer.
2Step 2
Get all components
Get all components listed in the components list.
Here some pictures:
- Fuse Holder
- XLR USB connector (RS-Components)
- A 12-24V to 2A@5V USB charger for a car
- M3 screws
3Step 3
Assembling the Accu-Pack adapter
4Step 4
Wiring and Finishing
5Addon - Spring loaded audio wire connector
I missed a fast way to connect a DC motor or a LED to the power supply without the need of 4mm banana connectors. Some of the other DPS5005 power supply projecs use sping loaded audio wire push connectors. I think, thats a very good idea and so i added one to my portable power supply.
You can probably make the contacts using this: 1/4" quick connect spade male
https://www.digikey.com/products/en/connectors-interconnects/terminals-adapters/405
for the switch or in general to connect something?
For your Accu-Pack adapter contacts. They are the same type of connector as the spades on your on/off switch (that you soldered). Those are actually for quick connect.
