(re)Mangetizing neodymium magnets
My attempts at replicating what Polymagnet are doing
Those who regularly watch youtube, might have seen video by SmarterEveryDay about a company called "Polymagnet".
https://youtu.be/IANBoybVApQ
http://www.polymagnet.com/
They can create arbitrary patterns of magnetization on neodymium magnets.
Guess what, I want a custom magnet. I contacted them. They kindly replied, and told me it would cost me no less than 2000$. Bam. FAIL. No way!
But can I hack something up to do it myself? let's try!
I want a magnet like this:
I want to fit as many poles as possible.
The plan is to obtain a disk magnet (even better if I get a ring magnet), heat it up to remove the original magnetization, and create new magnetization by discharging some capacitors into some coils.
It seems that it takes about 3.5 T of magnetic field to magnetize a neodymium magnet. Achieving this large a field with air core inductors is quite challenging. However, it is possible.
  • Magnet + magnetizer coil = loudspeaker
    DeepSOIC06/22/2017 at 22:11 0 comments
    Now that I've made a magnet using the coil, the magnetic field is just right to create a loudspeaker using that very coil as a voice coil. Cool, isn't it?
  • more magnetic = more better
    DeepSOIC06/18/2017 at 20:43 0 comments
    All my good caps in one big bank. Sixteen 350uF caps charged to 330V each, with total voltage of 1.3 kV, and stored energy of about 300 J.
    Discharged into a coil - 4 loops of 15-strand 0.17 mmdia magnet wire, R = 0.13 ohm, 4 uH. Which made a pulse of current of about 4.5 kA peak.
    which develped about 45 V across my home-made abuse-proof 10 mOhm resistor.
    The coil survived, but it was close. PLA plate has cracked because of coil self-repulsion. Most likely it was its last pulse.
    and the magnet is beautiful. It feels very strong. It is just a tiny bit not strong enough to levitate graphite. I think I am very close to full magnetization of the material.
    I made a small switch using salvaged contact bumps from a fridge thermostat relay. The switch made a very loud bang, and welded closed. I can't separate it. I need more robust contacts.
  • capacitor problems
    DeepSOIC06/18/2017 at 16:09 0 comments
    The capacitors I bought for this project are shit.
    They are SACON photo-flash electrolytic, rated for 350 uF 360 WV (WV == working voltage, AFAIK). When I charge one up (new capacitor!), it starts to seriously leak above about 250V. Which is a problem, because if some capacitors are leaking and others aren't, substantial charge imbalance in series connection can build up. This can cause low-leakage "cells" to charge up to more than rated voltage. And when the bank is discharged, leaky capacitors will end up with reversed polarity charge, which is very bad for their health.
    It seems that if I let the leaky capacitors leak for a while, the leak diminishes. So I've set up a "conditioning" process. I just soldered a few caps in parallel, and connected them via a rectifier to a variac, so that they are held at their rated voltage of 360 V till the leak disappears. The remaining leakage can be easily seen with thermal camera.
    This is a thermal camera shot of the capacitors in about 2 minutes after the voltage was applied.
    Their temperatures are reasonably even, apart from one cap, which I think I had conditioned previously already, I just forgot which one so I just soldered it into the bank.
    About 20 minutes later, I was wasting time in front of computer, when I heard the variac started roaring because of load current increasing. I rushed to switch it off, but before I did that, a bang happened. One capacitor has vented. It turned out, these capacitors contain a cloud worth of magic smoke! It all happened within 2 seconds I think. Luckily I was right next to it all to switch it off promptly, otherwise it might have resulted in a fire.
    Continuing the conditioning...
    most caps seem to be doing well, apart from three. Strangely they are right next to the one that vented. I think they might have been upset by the heat from that faulty one.
  • chooch factor overflow
    DeepSOIC06/17/2017 at 18:00 0 comments
    2kv pulse was all-right. 3 kV... BANG!
    That was a hell of a bang. It's ringing in my ears =( . I should wear headphones next time.
    I happened to have recorded the current pulse. I don't think it is useful for something, but here it is:
  • complex shape coil
    DeepSOIC06/17/2017 at 17:11 0 comments
    Yay! I just had success with impriting a more-or-less complex pattern into the magnet.
    Making the coil wasn't fun though.
    I 3d-printed a plate with a channel for the coil. Then I wound a coil of right length between two screws, and packed it into the channel. It went like 1) pack a small piece; 2) put some superglue, and push on top with polyethylene bag... repeat till done. Very annoying!
    But the results were worth it!
    The coil measures 2.43 Ohm, 73 uH, and has 20 loops (turns). It took a pulse of about 500 A to get appreciable magnetization. The capacitor bank was charged to 2 kV. It was ridiculously dangerous. And unfortunately, I want more!!
  • Having fun! Doodling on a magnet =)
    DeepSOIC06/09/2017 at 00:04 2 comments
  • Catastrophic failure of a coil
    DeepSOIC11/28/2016 at 00:13 0 comments
    So I wound a rough representation of a coil I want to use to magnetize the ultimate goal magnet.
    The first one was wound on a lamination plate from some transformer. When I connected it to capacitor, a loud bang followed. The insulation of wire failed, causing a dead short in the coil.
    Then I wound another one. I removed it from the carrier, and wicked with superglue to hold it together. When I pulsed it, agan a loud bang followed.
    Then I noticed that the coil looks a bit odd. OK, ripped apart by magnetic field. And only after careful investigation I realized how much did it actually deform. The places where there were sharp bends were straightened out, and new bends were created where the coil was straight. Wow, that was quite some force!
  • Quest to coil shape
    DeepSOIC11/27/2016 at 14:49 0 comments
    I did a bit of FEMM trial-and-error way to find a good pixel-making coil.
    None of the configurations I've tried so far is satisfactory, so I'm afraid I have to abandon CNC approach, and make coils specific to the magnetizaion pattern I want to make.
  • FEMM again
    DeepSOIC11/26/2016 at 21:23 0 comments
    Now, I have measured the pulse I used to create the pixel.
    Capacitor 350V 220 uF was discharged into the coil.
    464 A peak current.
    Then I measured the size of coil, and unwound it to count the number of turns.
    R = 0.5 Ohm
    thickness 2.4 mm
    inner d 1 mm
    outer d 3.2 mm
    top dia 2.2 mm
    cross section area (approx) 2.0 mm2
    N turns = 50
    => average current density in coil = 11600 MA/m^2
    FEMM results
    On this picture, I've set up color plot to span a range 0.5-3.5T. This range corresponds to magnetic field required to magnetize NdFeB: 0.5 is about where it starts to magnetize, and 3.5 is to achieve saturation.
    I've taken these values from http://dx.doi.org/10.3989/cyv.2005.v44.i3.385
    This isn't particularly correct, because magnetization affects magnetic field, and that can change what is actually magnetized. But I don't know how to simulate the process properly, so I'll stick to simple treatment for now.
  • Replacement for blown resistor
    DeepSOIC11/26/2016 at 18:56 0 comments
    Made my own resistor.
    I feel I'm crazy. I'm making my own resistors!
View all 16 project logs
3gfisch wrote 01/27/2020 at 22:30 point
very cool project, what have you done with the magnets? I’m also interested in doing my own magnets :)
DeepSOIC wrote 01/27/2020 at 23:24 point
Nothing, really.
Marian Keller wrote 07/04/2017 at 21:13 point
Great project, also wanted to do something like this after seeing SmarterEveryDay's video. But please consider some safety aspects, having those capacitors in parallel and charged lying openly on your bench. One slip and you'll get the shock of your life, probably even the last one.
DeepSOIC wrote 07/04/2017 at 22:10 point
"One slip and you'll get the shock of your life,"
- well, that also applies to driving a car. The difference is, in a car one has some good amount of instinctive feel for what is dangerous (yet driving is still freaking dangerous). Here, these wires look no more dangerous when energized, compared to when they are not energized.
No worries, multiverse interpretation of quantum mechanics means I'm immortal =P
Morning.Star wrote 03/28/2017 at 11:07 point
Fascinating project :-)
Single-plane bifilar coils a la Tesla produce a much denser field at the centre. They can also be formed into a shallow cone to better focus the field outside the plane of the coil along it's axis. Because the electron path through the coil makes two passes effectively, you dont get such dramatic torsion with a short sharp pulse. The geometry also allows for a tidier and sturdier coil to be built using the same wire.
Stanislav Zubenko wrote 11/24/2016 at 21:16 point
Wish you good luck, maybe try:
1)More powerfull electromagnet?
2)Longer expose?
3)Concentrating magnetic field?
