Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Room Thermostat PIC16F628A
Room thermostat using DS18B20 sensor and OLED display.
projecterprojecter
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 7
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
70
0
2
2
Team (1)
  • projecterprojecter
Join this project's team
completed project
hardware
pic16F628 oled ds18b20
This project was created on 05/23/2022 and last updated 1 個月前.
Description
OLED display, 128x64, 0.96", SSD1306, I2C with PIC16F628A. Oled is driven by software (bit banging) I2C. Setting the room temperature by 2 buttons.
Output transistor is to drive a relay or directly 24VDC input to a central heating boiler. Hysteresis is 0.5 degree. Update of the temperature is every second.
Temperature range is -55 to 100 centigrade.
Details
Files
oled room thermostat rev2.zip
x-zip-compressed - 18.20 kB - 05/23/2022 at 13:58
Download
Components
  • 1 × PIC16F628A Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × OLED display, 128x64, 0.96", SSD1306, I2C
  • 1 × DS18B20 sensor
  • 2 × pushbutton
  • 2 × resistor 470 ohm
View all 7 components
Log In/Sign up to comment
Sign up with Github
OR
Gsm temperature monitoring
Project Owner Contributor
gsm temperature monitoring
mishamisha
Here we will make a web server to display the temperature using LM35 as a temperature sensor.
IoT Digital Thermometer using LM35 and NodeMCU
hIOTronhIOTron
Monitor temperature and humidity over wifi.
MQTT Temperature and Humidity Monitor
Liz CorsonLiz Corson
Monitor current temperature and humidity and tack via USB
Simple USB Temperature and Humidity Logger
Dan PolnoffDan Polnoff
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "Room Thermostat PIC16F628A", please tell us the reason.
Send message
Remove Member
