Getting to know your Robot Vacuum
A project log for Shark Robot Vacuum Reverse Engineering
Reverse engineering the Shark RV1001AED series Robot Vacuum
Jon SteelJon Steel 05/24/2022 at 19:040 Comments
STEP1: Communication, sprechen sie beep boop?
So a great place to start with almost any reverse engineering project is finding the UARTS.
One difference with the L02 PCB vs the L01 is the lack of silk screen information besides some model info text.
Lucky for us, the UART test pads stick out like poorly hidden UART test pads. Three test pads in a row with no other pads around, and one of the pads is tied to ground.
Solder on some test leads, connect to USB/UART adapter. Set serial port to 1500000,8,N,1
Pull the lever Kronk!
DDR V1.14 20190925
D3,512MB,333MHz
bw	col	bk	row	cs	dbw
32	10	8	14	1	16
OUT
Boot1 Release Time: Sep 24 2019 13:27:46, version: 1.20
chip_id:524b3326_0,0
ChipType = 0x12, 460
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=1000
UserCapSize=3776MB
FwPartOffset=2000 , 1000
SdmmcInit=0 NOT PRESENT
StorageInit ok = 27271
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x404
Secure read PBA: 0x804
Secure read PBA: 0xc04
Secure read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part:  0, name:            uboot, start:0x4000, size:0x2000
GPT part:  1, name:            trust, start:0x6000, size:0x2000
GPT part:  2, name:             misc, start:0x8000, size:0x2000
GPT part:  3, name:             boot, start:0xa000, size:0x10000
GPT part:  4, name:         recovery, start:0x1a000, size:0x10000
GPT part:  5, name:           backup, start:0x2a000, size:0x10000
GPT part:  6, name:              oem, start:0x3a000, size:0x3c000
GPT part:  7, name:           rootfs, start:0x76000, size:0x200000
GPT part:  8, name:              sys, start:0x276000, size:0x5000
GPT part:  9, name:         userdata, start:0x27b000, size:0x4e4fdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xcafd4
RunBL31 0x40000 @ 74562 us
INFO:    Preloader serial: 2
NOTICE:  BL31: v1.3(debug):ca3dd02
NOTICE:  BL31: Built : 10:15:38, Sep 23 2019
NOTICE:  BL31:Rockchip release version: v1.0
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status f00e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (Jul 07 2020 - 18:40:52 +0800)
Model: Rockchip RK3326 EVB
PreSerial: 2
DRAM:  510 MiB
Sysmem: init
Relocation Offset is: 1dbef000
Using default environment
dwmmc@ff370000: 1, dwmmc@ff390000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC:  RK8090 (on=0x40, off=0x00)
vdd_logic 1100000 uV
vdd_arm 1100000 uV
Model: Rockchip rk3326 evb lpddr3 v10 board for robot linux
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 600000 KHz)
  apll 600000 KHz
  dpll 664000 KHz
  cpll 24000 KHz
  npll 1188000 KHz
  gpll 1200000 KHz
  aclk_bus 200000 KHz
  hclk_bus 150000 KHz
  pclk_bus 100000 KHz
  aclk_peri 200000 KHz
  hclk_peri 150000 KHz
  pclk_pmu 100000 KHz
Net:   Net Initialization Skipped
No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
ANDROID: reboot reason: "(none)"
Fdt Ramdisk skip relocation
Booting LZ4 kernel at 0x03e80000(Uncompress to 0x00280000) with fdt at 0x8300000...
## Booting Android Image at 0x03e7f800 ...
Kernel load addr 0x00280000 size 4179 KiB
## Flattened Device Tree blob at 08300000
   Booting using the fdt blob at 0x8300000
   Uncompressing Kernel Image ... OK
  'reserved-memory' ramoops@00000000: addr=8000000 size=a0000
   Using Device Tree in place at 0000000008300000, end 0000000008317ef7
Adding bank: 0x00200000 - 0x20000000 (size: 0x1fe00000)
Total: 391.595 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.189 (zxg@zxg) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP PREEMPT Tue Jul 7 17:42:53 CST 2020
[    0.000000] Boot CPU: AArch64 Processor [410fd042]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 19 pages/cpu @ffffffc01ff3d000 s36968 r8192 d32664 u77824
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 128520
[    0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  androidboot.slot_suffix= androidboot.serialno=L02M01VB__L105200823H01NF  rootwait swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000
[    0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.000000] software IO TLB: mapped [mem 0x1fe39000-0x1fe79000] (0MB)
[    0.000000] Memory: 501840K/522240K available (5182K kernel code, 414K rwdata, 1896K rodata, 384K init, 1694K bss, 20400K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8008770000 - 0xffffff80087d0000   (   384 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008590000   (  5184 KB)
[    0.000000]     .rodata : 0xffffff8008590000 - 0xffffff8008770000   (  1920 KB)
[    0.000000]       .data : 0xffffff80087d0000 - 0xffffff8008837808   (   415 KB)
[    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc020000000   (   510 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001729] Console: colour dummy device 80x25
[    0.001771] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[    0.001796] pid_max: default: 32768 minimum: 301
[    0.002013] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
[    0.002035] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
[    0.003187] Initializing cgroup subsys devices
[    0.003229] Initializing cgroup subsys freezer
[    0.003781] sched-energy: CPU device node has no sched-energy-costs
[    0.003805] Invalid sched_group_energy for CPU0
[    0.003822] CPU0: update cpu_capacity 1024
[    0.003896] ASID allocator initialised with 32768 entries
[    0.015198] Detected VIPT I-cache on CPU1
[    0.015275] Invalid sched_group_energy for CPU1
[    0.015284] CPU1: update cpu_capacity 1024
[    0.015291] CPU1: Booted secondary processor [410fd042]
[    0.018263] Detected VIPT I-cache on CPU2
[    0.018321] Invalid sched_group_energy for CPU2
[    0.018330] CPU2: update cpu_capacity 1024
[    0.018337] CPU2: Booted secondary processor [410fd042]
[    0.021344] Detected VIPT I-cache on CPU3
[    0.021400] Invalid sched_group_energy for CPU3
[    0.021407] CPU3: update cpu_capacity 1024
[    0.021414] CPU3: Booted secondary processor [410fd042]
[    0.021557] Brought up 4 CPUs
[    0.021646] SMP: Total of 4 processors activated.
[    0.021668] CPU features: detected feature: 32-bit EL0 Support
[    0.021690] CPU: All CPU(s) started at EL2
[    0.022047] Invalid sched_group_energy for CPU3
[    0.022073] Invalid sched_group_energy for Cluster3
[    0.022089] Invalid sched_group_energy for CPU2
[    0.022107] Invalid sched_group_energy for Cluster2
[    0.022122] Invalid sched_group_energy for CPU1
[    0.022140] Invalid sched_group_energy for Cluster1
[    0.022155] Invalid sched_group_energy for CPU0
[    0.022173] Invalid sched_group_energy for Cluster0
[    0.023763] devtmpfs: initialized
[    0.097975] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.098033] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.098928] pinctrl core: initialized pinctrl subsystem
[    0.101731] NET: Registered protocol family 16
[    0.108344] cpuidle: using governor menu
[    0.108430] Registered FIQ tty driver
[    0.108764] vdso: 2 pages (1 code @ ffffff8008596000, 1 data @ ffffff80087d4000)
[    0.108833] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.109087] DMA: preallocated 256 KiB pool for atomic allocations
[    0.188816] genirq: Setting trigger mode 8 for irq 170 failed (gic_set_type+0x0/0x48)
[    0.191146] console [pstore-1] enabled
[    0.191169] pstore: Registered ramoops as persistent store backend
[    0.191192] ramoops: attached 0xa0000@0x8000000, ecc: 0/0
[    0.242206] console [ttyFIQ0] enabled
[    0.243275] Registered fiq debugger ttyFIQ0
[    0.266390] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    0.269351] vccio_sdio: regulator get failed, ret=-517
[    0.270715] vccio_dvp: regulator get failed, ret=-517
[    0.272110] vccio_flash: regulator get failed, ret=-517
[    0.275349] iommu: Adding device ff440000.hevc_service to group 0
[    0.276196] iommu: Adding device ff442000.vpu_service to group 1
[    0.277018] iommu: Adding device ff460000.vop to group 2
[    0.277762] iommu: Adding device ff4a0000.rkisp1 to group 3
[    0.279862] rk_iommu ff440440.iommu: can't get sclk
[    0.281182] rk_iommu ff442800.iommu: can't get sclk
[    0.282181] rk_iommu ff460f00.iommu: can't get sclk
[    0.283252] rk_iommu ff490800.iommu: can't get sclk
[    0.284207] rk_iommu ff4a8000.iommu: can't get sclk
[    0.285397] media: Linux media interface: v0.10
[    0.286008] Linux video capture interface: v2.00
[    0.289330] Advanced Linux Sound Architecture Driver Initialized.
[    0.293953] rockchip-cpuinfo cpuinfo: Serial		: 543c9333f8324d3b
[    0.295607] clocksource: Switched to clocksource arch_sys_counter
[    0.330740] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.332103] NET: Registered protocol family 2
[    0.333860] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.334627] TCP bind hash table entries: 4096 (order: 5, 131072 bytes)
[    0.335389] TCP: Hash tables configured (established 4096 bind 4096)
[    0.336130] UDP hash table entries: 256 (order: 2, 24576 bytes)
[    0.336746] UDP-Lite hash table entries: 256 (order: 2, 24576 bytes)
[    0.337911] NET: Registered protocol family 1
[    0.341525] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.377541] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.385327] NET: Registered protocol family 38
[    0.385892] io scheduler noop registered (default)
[    0.389691] phy phy-ff2c0000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator
[    0.397331] rk-vcodec vpu_combo: no regulator for vcodec
[    0.398572] rk-vcodec vpu_combo: failed on clk_get clk_cabac
[    0.399413] platform ff442000.vpu_service: probe device
[    0.400787] platform ff442000.vpu_service: drm allocator with mmu enabled
[    0.403474] platform ff440000.hevc_service: probe device
[    0.404810] platform ff440000.hevc_service: drm allocator with mmu enabled
[    0.406951] rk-vcodec vpu_combo: could not find power_model node
[    0.407510] rk-vcodec vpu_combo: init success
[    0.419772] dma-pl330 ff240000.dmac: Loaded driver for PL330 DMAC-241330
[    0.420410] dma-pl330 ff240000.dmac: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.422043] rockchip-pvtm ff010000.syscon:pmu-pvtm: failed to get rst 0 pmu
[    0.423128] rockchip-pvtm ff148000.syscon:pvtm: failed to get rst 0 core
[    0.425491] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.427857] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.430145] ff030000.serial: ttyS0 at MMIO 0xff030000 (irq = 10, base_baud = 6250000) is a 16550A
[    0.432681] ff178000.serial: ttyS5 at MMIO 0xff178000 (irq = 13, base_baud = 6250000) is a 16550A
[    0.439316] random: nonblocking pool is initialized
[    0.439648] [drm] Initialized drm 1.1.0 20060810
[    0.442237] [drm] Rockchip DRM driver version: v1.0.1
[    0.443310] rockchip-drm display-subsystem: devfreq is not set
[    0.445564] rockchip-drm display-subsystem: bound ff460000.vop (ops 0xffffff80085eced0)
[    0.446338] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.446964] [drm] No driver support for vblank timestamp query.
[    0.447753] rockchip-drm display-subsystem: failed to parse display resources
[    0.449347] rockchip-drm display-subsystem: master bind failed: -22
[    0.450022] rockchip-drm: probe of display-subsystem failed with error -22
[    0.452110] mali ff400000.gpu: Failed to get regulator
[    0.452620] mali ff400000.gpu: Power control initialization failed
[    0.454311] Unable to detect cache hierarchy for CPU 0
[    0.457114] zram: Added device: zram0
[    0.457556] lkdtm: No crash points registered, enable through debugfs
[    0.463532] Rockchip WiFi SYS interface (V1.00) ...
[    0.465077] ff300000.usb supply vusb_d not found, using dummy regulator
[    0.465919] ff300000.usb supply vusb_a not found, using dummy regulator
[    0.469096] dwc2 ff300000.usb: Configuration mismatch. dr_mode forced to device
[    0.469822] dwc2 ff300000.usb: 128 invalid for host_nperio_tx_fifo_size. Check HW configuration.
[    0.470637] dwc2 ff300000.usb: 256 invalid for host_perio_tx_fifo_size. Check HW configuration.
[    0.471519] dwc2 ff300000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    0.475816] i2c /dev entries driver
[    0.479870] rk808 0-0020: Pmic Chip id: 0x8090
[    0.480844] rk808 0-0020: source: on=0x40, off=0x00
[    0.482281] rk808 0-0020: support dcdc3 fb mode:-22, 510001152
[    0.483191] rk808 0-0020: support pmic reset mode:0,1
[    0.489748] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    0.490344] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    0.491269] DCDC_REG1: supplied by vcc5v0_sys
[    0.494958] DCDC_REG2: supplied by vcc5v0_sys
[    0.498479] DCDC_REG3: supplied by vcc5v0_sys
[    0.501752] DCDC_REG4: supplied by vcc5v0_sys
[    0.504648] vccio_sdio: supplied by vcc_3v0
[    0.505827] DCDC_REG5: supplied by vcc5v0_sys
[    0.508647] LDO_REG1: supplied by vcc3v3_sys
[    0.512167] LDO_REG2: supplied by vcc3v3_sys
[    0.515510] vccio_flash: supplied by vcc1v8_soc
[    0.516525] LDO_REG3: supplied by vcc3v3_sys
[    0.520042] LDO_REG4: supplied by vcc3v3_sys
[    0.523569] LDO_REG5: supplied by vcc3v3_sys
[    0.526222] LDO_REG6: supplied by vcc3v3_sys
[    0.527372] vcc_sd: Bringing 3000000uV into 3300000-3300000uV
[    0.530126] LDO_REG7: supplied by vcc3v3_sys
[    0.532678] LDO_REG8: supplied by vcc3v3_sys
[    0.534949] vccio_dvp: supplied by vcc1v8_dvp
[    0.536844] LDO_REG9: supplied by vcc3v3_sys
[    0.539436] SWITCH_REG1: supplied by vcc5v0_sys
[    0.541879] SWITCH_REG2: supplied by vcc3v3_sys
[    0.544742] rk817-battery rk817-battery: Failed to find matching dt id
[    0.545929] rk817-charger rk817-charger: Failed to find matching dt id
[    0.550209] input: rk8xx_pwrkey as /devices/platform/ff180000.i2c/i2c-0/0-0020/input/input0
[    0.556900] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    0.559698] rk3x-i2c ff180000.i2c: Initialized RK3xxx I2C bus at ffffff8008aee000
[    0.562895] rk3x-i2c ff1a0000.i2c: Initialized RK3xxx I2C bus at ffffff8008af0000
[    0.565470] rkisp1 ff4a0000.rkisp1: rkisp1 driver version: v00.01.05
[    0.579064] Boot mode: coldboot
[    0.581278] rockchip-thermal ff280000.tsadc: Missing tshut mode property, using default (cru)
[    0.582109] rockchip-thermal ff280000.tsadc: Missing tshut-polarity property, using default (low)
[    0.583126] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[    0.584419] rockchip-thermal ff280000.tsadc: tsadc is probed successfully!
[    0.587381] cpu cpu0: bin=0
[    0.587791] cpu cpu0: leakage=9
[    0.602324] cpu cpu0: temp=31818, pvtm=52402 (51898 + 504)
[    0.604230] cpu cpu0: pvtm-volt-sel=1
[    0.604876] cpu cpu0: bin-scale=13
[    0.609099] cpu cpu0: avs=0
[    0.609562] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    0.612702] cpu cpu0: failed to find power_model node
[    0.615934] Synopsys Designware Multimedia Card Interface Driver
[    0.619004] dwmmc_rockchip ff380000.dwmmc: num-slots property not found, assuming 1 slot is available
[    0.620071] dwmmc_rockchip ff380000.dwmmc: IDMAC supports 32-bit address mode.
[    0.620810] dwmmc_rockchip ff380000.dwmmc: Using internal DMA controller.
[    0.621438] dwmmc_rockchip ff380000.dwmmc: Version ID is 270a
[    0.622138] dwmmc_rockchip ff380000.dwmmc: DW MMC controller at irq 21,32 bit host data width,256 deep fifo
[    0.623214] dwmmc_rockchip ff380000.dwmmc: No vmmc regulator found
[    0.623812] dwmmc_rockchip ff380000.dwmmc: No vqmmc regulator found
[    0.624957] dwmmc_rockchip ff380000.dwmmc: allocated mmc-pwrseq
[    0.639018] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.652761] dwmmc_rockchip ff380000.dwmmc: 1 slots initialized
[    0.654663] dwmmc_rockchip ff390000.dwmmc: IDMAC supports 32-bit address mode.
[    0.655456] dwmmc_rockchip ff390000.dwmmc: Using internal DMA controller.
[    0.656171] dwmmc_rockchip ff390000.dwmmc: Version ID is 270a
[    0.656887] dwmmc_rockchip ff390000.dwmmc: DW MMC controller at irq 22,32 bit host data width,256 deep fifo
[    0.657997] dwmmc_rockchip ff390000.dwmmc: No vmmc regulator found
[    0.658569] dwmmc_rockchip ff390000.dwmmc: No vqmmc regulator found
[    0.660540] dwmmc_rockchip ff380000.dwmmc: card claims to support voltages below defined range
[    0.672860] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.672893] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    0.674250] mmc0: new high speed SDIO card at address 0001
[    0.687930] dwmmc_rockchip ff390000.dwmmc: 1 slots initialized
[    0.696462] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[    0.699920] rknandc_base v1.1 2017-01-11
[    0.708697] NET: Registered protocol family 17
[    0.709254] NET: Registered protocol family 15
[    0.709717] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    0.710939] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    0.711421] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8189fs
[    0.712101] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    0.712805] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    0.713668] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 5, flags = 0.
[    0.714508] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    0.715221] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    0.715740] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    0.716453] [BT_RFKILL]: Enter rfkill_rk_init
[    0.718603] flash vendor_init_thread!
[    0.718955] flash vendor storage:20170308 ret = -1
[    0.719192] ov7251 2-0060: driver version: 00.01.01
[    0.719403] ov7251 2-0060: Failed to get pwdn-gpios
[    0.723572] ov7251 2-0060: Unexpected sensor id(000000), ret(-5)
[    0.725614] Registered cp15_barrier emulation handler
[    0.726172] Registered setend emulation handler
[    0.730343] rga2: Driver loaded successfully ver:4.00
[    0.731311] rga2: Module initialized.
[    0.733729] mali ff400000.gpu: Failed to get leakage
[    0.734721] mali ff400000.gpu: pvtm-volt-sel=1
[    0.736378] mali ff400000.gpu: avs=0
[    0.736823] W : [File] : drivers/gpu/arm/bifrost_for_linux/platform/rk/mali_kbase_config_rk.c; [Line] : 135; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[    0.739668] mali ff400000.gpu: GPU identified as 0x3 arch 7.0.9 r0p0 status 0
[    0.741907] mali ff400000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    0.743056] mali ff400000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[    0.746242] mali ff400000.gpu: Probed as mali0
[    0.748039] rockchip-dmc dmc: current ATF version 0x105!
[    0.748541] rockchip-dmc dmc: read tf version 0x105!
[    0.751967] rockchip-dmc dmc: Failed to get leakage
[    0.752907] rockchip-dmc dmc: pvtm-volt-sel=1
[    0.754627] rockchip-dmc dmc: avs=0
[    0.755022] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[    0.755631] rockchip-dmc dmc: failed to get vop pn to msch rl
[    0.756706] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    0.759562] devfreq dmc: Couldn't update frequency transition information.
[    0.764122] asoc-simple-card rk809-sound: rk817-hifi <-> ff070000.i2s mapping ok
[    0.764856] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[    0.765544] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack
[    0.766360] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[    0.767018] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P
[    0.767808] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[    0.768469] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack
[    0.769302] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[    0.769981] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack
[    0.773358] ov7251 2-0060: driver version: 00.01.01
[    0.774114] ov7251 2-0060: Failed to get pwdn-gpios
[    0.778408] ov7251 2-0060: Unexpected sensor id(000000), ret(-5)
[    0.779165] mmc_host mmc1: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[    0.782877] input: gpio_keys as /devices/platform/gpio_keys/input/input1
[    0.785546] ov7251 2-0060: driver version: 00.01.01
[    0.786265] ov7251 2-0060: Failed to get pwdn-gpios
[    0.786739] rk808-rtc rk808-rtc: setting system clock to 2017-08-05 09:00:01 UTC (1501923601)
[    0.791263] ov7251 2-0060: Unexpected sensor id(000000), ret(-5)
[    0.834320] vccio_sdio: disabling
[    0.834685] vccio_dvp: disabling
[    0.834983] vccio_flash: disabling
[    0.835531] vccio_sd: disabling
[    0.836277] vcc_sd: disabling
[    0.837272] vcc3v3_lcd: disabling
[    0.838073] rkisp1 ff4a0000.rkisp1: clear unready subdev num: 1
[    0.839670] rockchip-mipi-dphy-rx: No link between dphy and sensor
[    0.840239] rockchip-mipi-dphy-rx: No link between dphy and sensor
[    0.840826] rkisp1: update sensor failed
[    0.842306] ALSA device list:
[    0.842633]   #0: rockchip,rk809-codec
[    0.843372] Waiting for root device PARTUUID=614e0000-0000...
[    1.044544] dwmmc_rockchip ff390000.dwmmc: Successfully tuned phase to 201
[    1.045982] mmc1: new HS200 MMC card at address 0001
[    1.049260] mmcblk1: mmc1:0001 004GA0 3.69 GiB
[    1.051320] mmcblk1boot0: mmc1:0001 004GA0 partition 1 2.00 MiB
[    1.053376] mmcblk1boot1: mmc1:0001 004GA0 partition 2 2.00 MiB
[    1.056357] mmcblk1rpmb: mmc1:0001 004GA0 partition 3 512 KiB
[    1.069472]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    1.087421] ov7251 2-0060: driver version: 00.01.01
[    1.088343] ov7251 2-0060: Failed to get pwdn-gpios
[    1.094074] ov7251 2-0060: Unexpected sensor id(000000), ret(-5)
[    1.154590] VFS: Mounted root (squashfs filesystem) readonly on device 179:8.
[    1.159157] devtmpfs: mounted
[    1.160118] Freeing unused kernel memory: 384K
[    1.257758] vendor storage:20190527 ret = 0
Starting logging: OK
Welcome to Rockchip Linux SDK
Populating /dev using udev: [    1.656776] udevd[139]: starting version 3.2.7
[    1.681042] udevd[139]: specified group 'kvm' unknown
[    1.700271] udevd[141]: starting eudev-3.2.7
done
read-only file system detected...done
Will now mount all partitions in /etc/fstab
Note: Create /.skip_fsck to skip fsck
 - The check might take a while if didn't shutdown properly!
Handling /dev/mmcblk1p8 / ext2 rw,noauto 1
Wrong fs type(ext2) for /dev/mmcblk1p8
Handling /dev/mmcblk1p3 /misc emmc defaults 0
Unsupported file system emmc for /dev/mmcblk1p3
Handling /dev/mmcblk1p7 /mnt/res ext2 defaults 2
Checking /dev/mmcblk1p7(ext2)
e2fsck 1.43.9 (8-Feb-2018)
oem was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Free blocks count wrong (52685, counted=52684).
Fix? yes
Free inodes count wrong (17138, counted=17137).
Fix? yes
oem: ***** FILE SYSTEM WAS MODIFIED *****
oem: 143/17280 files (23.8% non-contiguous), 70196/122880 blocks
Mounting /dev/mmcblk1p7(ext2) on /mnt/res
[    3.318725] EXT4-fs (mmcblk1p7): couldn't mount as ext3 due to feature incompatibilities
[    3.319984] EXT4-fs (mmcblk1p7): mounting ext2 file system using the ext4 subsystem
[    3.324911] EXT4-fs (mmcblk1p7): mounted filesystem without journal. Opts: (null)
Handling /dev/mmcblk1p10 /mnt/udisk ext2 defaults 2
Checking /dev/mmcblk1p10(ext2)
Superblock last mount time is in the future.
	(by less than a day, probably due to the hardware clock being incorrectly set)
Superblock last write time is in the future.
userdata was not cleanly unmounted, check forced.
userdata: 157/160768 files (68.2% non-contiguous), 46622/2566124 blocks
Mounting /dev/mmcblk1p10(ext2) on /mnt/udisk
[    5.456402] EXT4-fs (mmcblk1p10): couldn't mount as ext3 due to feature incompatibilities
[    5.457461] EXT4-fs (mmcblk1p10): mounting ext2 file system using the ext4 subsystem
[    5.469706] EXT4-fs (mmcblk1p10): mounted filesystem without journal. Opts: (null)
Handling /dev/mmcblk1p9 /mnt/sys ext2 defaults 2
Checking /dev/mmcblk1p9(ext2)
sys: recovering journal
sys: clean, 11/2304 files, 1405/10240 blocks
Mounting /dev/mmcblk1p9(ext2) on /mnt/sys
[    5.692290] EXT4-fs (mmcblk1p9): couldn't mount as ext3 due to feature incompatibilities
[    5.693960] EXT4-fs (mmcblk1p9): couldn't mount as ext2 due to feature incompatibilities
[    5.699037] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: (null)
Log saved to /tmp/mountall.log
Starting network: OK
Starting dhcpcd...
no valid interfaces found
no interfaces have a carrier
forked to background, child pid 551
Starting watch_ntpd.sh: OK
Starting sshd: run ntpd once and watch it every 86400 seconds
 5 Aug 09:00:06 ntpd[563]: ntpd 4.2.8p10@1.3728-o Tue Jul  7 09:56:56 UTC 2020 (1): Starting
 5 Aug 09:00:06 ntpd[563]: Command line: ntpd -gq
OK
 5 Aug 09:00:06 ntpd[563]: proto: precision = 0.583 usec (-21)
 5 Aug 09:00:06 ntpd[563]: restrict: ignoring line 11, address/host '[::1]' unusable.
 5 Aug 09:00:06 ntpd[563]: Listen and drop on 0 v4wildcard 0.0.0.0:123
 5 Aug 09:00:06 ntpd[563]: Listen normally on 1 lo 127.0.0.1:123
 5 Aug 09:00:06 ntpd[563]: Listening on routing socket on fd #18 for interface updates
Debug: configfs_init
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0': No such file or directory
[    6.071977] file system registered
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/rndis.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mass_storage.0': No such file or directory
[    6.186204] read descriptors
[    6.186500] read strings
[    7.205403] dwc2 ff300000.usb: bound driver configfs-gadget
load wifi modules: WIFI_CHANNEL_PLAN=0x00
[    7.420224]
[    7.420394] =======================================================
[    7.421025] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[    7.421635] =======================================================
[    7.422204] Realtek 8723DS SDIO WiFi driver (Powered by Rockchip,Ver v5.3.12_28613.20180703) init.
[    7.423029] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    7.423453] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    7.424277] [WLAN_RFKILL]: wifi turn on power. -1
[    7.424775] mmc0:mmc host rescan start!
[    8.425686] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    8.650483] ov7251 2-0060: driver version: 00.01.01
[    8.651310] ov7251 2-0060: Failed to get pwdn-gpios
[    8.660184] ov7251 2-0060: Unexpected sensor id(000000), ret(-5)
Starting dnsmasq: OK
[qfeel]===> set GPIO0_B5(for imu SENSOR_INIT) as input mode
[qfeel]===> set GPIO3_D0 and GPIO3_D1 (fct and stresstest used) as input mode
[qfeel]===> Find checkBootAuto.sh in dir:/usr/local
Welcome to RK3326 Buildroot For Robot
rk3326_robot64 login: : path:"/mnt/res/app"
chmod: cannot access '/mnt/res/www/lighttpd': No such file or directory
Start Normally
appd OK
[    9.969163] rtw_drv_log_level:0
rebootUpload
search cmd cat /mnt/udisk/tmp/log1/upload.cmd
Successfully initialized wpa_supplicant
cat: /mnt/udisk/tmp/log1/upload.cmd: No such file or directory
logPathDir /tmp/ ,fullPath
file_udisk_bak 8
regex:(\w+)MST::(\w+)
pbInputBase64
enable 0
regex:(\w+)(\w+)
pbInputBase64
enable 0
config size 2097152,log rotate size 5356324
logFilter get msgId :0
OK
OK
sh: you need to specify whom to kill
2017-08-05 09:00:11: (configfile.c.1390) server.upload-dirs doesn't exist: /mnt/sdcard/
[   10.599539] rtw_drv_log_level:0
[   11.094856] sh (754): drop_caches: 3
Client mosq/rRt1uwd@HMw?TLZfeR sending CONNECT
Client mosq/rRt1uwd@HMw?TLZfeR sending PUBLISH (d0, q0, r0, m1, '/viper/wifiOut', ... (11 bytes))
Client mosq/rRt1uwd@HMw?TLZfeR received CONNACK
Client mosq/rRt1uwd@HMw?TLZfeR sending SUBSCRIBE (Mid: 2, Topic: /viper/wifiIn, QoS: 2)
Client mosq/rRt1uwd@HMw?TLZfeR received SUBACK
Subscribed (mid: 2): 2
Client mosq/rRt1uwd@HMw?TLZfeR sending PUBLISH (d0, q0, r0, m3, '/viper/wifiOut', ... (11 bytes))
Client mosq/rRt1uwd@HMw?TLZfeR sending PUBLISH (d0, q0, r0, m4, '/viper/wifiOut', ... (11 bytes))
Client mosq/rRt1uwd@HMw?TLZfeR received PUBLISH (d0, q0, r0, m0, '/viper/wifiIn', ... (37 bytes))
/viper/wifiIn WiFiSSIDShark_RV1100A-NA-PIMP-MAC-DADDY
 5 Aug 09:00:19 ntpd[563]: Listen normally on 2 wlan0 192.168.1.172:123
13 May 07:57:48 ntpd[563]: Listen normally on 3 wlan0 192.168.1.171:123
13 May 07:57:48 ntpd[563]: 138.197.15.27 local addr 192.168.1.172 -> 192.168.1.171
13 May 07:57:48 ntpd[563]: 168.61.215.74 local addr 192.168.1.172 -> 192.168.1.171
13 May 07:57:52 ntpd[563]: ntpd: time set +0.298956 s
ntpd: time set +0.298956s
 Wow! First try! It is almost like I have done this before!
Plenty of tastey information!
