WE GOT ROOT!
A project log for Shark Robot Vacuum Reverse Engineering
Reverse engineering the Shark RV1001AED series Robot Vacuum
jon-steelJon Steel 05/30/2022 at 09:480 Comments
Well I decided to play some risky biscuits, and  reading up on rockchip documentation I found I can do an upgrade without over writing the entire firmware... **REDACTED**... used the Rkdevtool to upgrade, and all was good!
Did a wget spider to see what it would do...
Sorry, this content has been removed due to the lawyers at SharkNinja.
next job is to get ssh working, and then I can update the lame voice packs.
