Pulling My hair out!
A project log for Shark Robot Vacuum Reverse Engineering
Reverse engineering the Shark RV1001AED series Robot Vacuum
jon-steelJon Steel 06/05/2022 at 07:290 Comments
So a problem I have had for some time is getting ADB to work.
I have it setup in init.d for ADB to work, and I can run ADB on my computer to see the device SN, but it says UNAUTHORIZED.
I have tried all I can think of as for the common issues with ADB giving an Unauthorized.
The main culprit I think it there is no mechanism on the Robot to accept the ADB connection request like you would with a phone or tablet.
I can't find anything in the ADC keys or GPIO keys in relation to ADB, but then again I can't find anything about the ADC key I found to get into recovery mode...
Any suggestions?
