Forget you ADB! Hi GDB!
A project log for Shark Robot Vacuum Reverse Engineering
Reverse engineering the Shark RV1001AED series Robot Vacuum
jon-steelJon Steel 06/09/2022 at 16:100 Comments
After wasting too much time with ADB, I decided to move on. Next on the list is to use GDB and Ghidra to RE some of the applications. The main application I am interested in is the **REDACTED**. Initial analysis shows this is where all of the VSLAM calculations are done, and the RVC_Base inputs are polled.
This will be a fun weekend!
