An unexpected problem
A project log for Anycubic Wash And Cure 2.0 Silent Mod
The stock driver is too loud. Let's quiet it down!
torbjrn-lindholmTorbjörn Lindholm 05/25/2022 at 17:420 Comments
Weirdly, at any current limit settings, the motor will start to spin, then stop. This works fine on the Cure mode (which worked fine on the A4988 too), however, the crucial Wash mode doesn't work. It only goes up to a certain speed, then stalls and vibrates. I tried everything and it's already 3AM, so I'll try again tomorrow.
