Info dump
A project log for Anycubic Wash And Cure 2.0 Silent Mod
The stock driver is too loud. Let's quiet it down!
torbjrn-lindholmTorbjörn Lindholm 06/01/2022 at 03:530 Comments
The front panel uses TM1638. The first 4 scan segments are used for the numbers and the colon mark, and the rest is used for the LEDs.
The encoder wheel seems to be wired directly to the MCU with pull-up resistors.
The connection:
 ^ Tab ^
[1234567]
 1: VCC (5V)
2: EN2 (Encoder Right)
3: EN1 (Encoder Left)
4: GND
5: DIO
6: CLK
7: STB
