M-BUS HAT for Raspberry Pi
M-BUS HAT to extend your Raspberry Pi with smartmetering functions
Public Chat
With this Raspberry Pi HAT you can extend your Raspberry Pi with functions for smart metering. The HAT provides an M-Bus master to which other M-Bus devices such as electricity, water or gas meters (with the appropriate interface) can be connected directly. The M-Bus interface is an European standard (EN 13757-2 and EN 13757-3) made for communication on two wires, making it very cost effective.
Features:
  • M-Bus (Meter-Bus) Master
  • powered by an external 9..30V DC voltage (36V for the MBUS will be generated internally from this voltage)
  • up to 6 unit loads can be powered
  • isolated interface
  • selectable UART via jumper (with Raspberry Pi 4 only)
  • indicator LEDs for RX and TX
  • removable block terminal for bus connection
  • stackable headers version available
more information
Datasheet MBUS HAT Rev A.pdf
Manual for configuration and software installation
Adobe Portable Document Format - 887.38 kB - 06/17/2022 at 06:42
Preview
Download
View project log
