Sci-Fi 3D Printed Mask With Transparent Display
A Sci-Fi 3D Printed Winter Soldier Mask With Transparent Displays.
This Mask is a 3D Printed Winter Soldier mask from Capital America Civil War, I have modified the mask by adding two Transparent OLED Displays as the eyes of the Mask. This are 128×64 pixels OLED see through displays from DFRobot.com which I am using for showing few animations. Since the display are transparent I can see through them even when the pixels are on. The transparent display are two way display, means the image is visible on the both side but inverted at one side. The aim of this project is to make others see the animating eyes, even the image is visible on both side the person wearing the mask cannot see the display content since the displays is too close to the eyes to focus. To switch between different animations and texts I have used Blynk app.
  • 2 × Transparent Display https://www.dfrobot.com/product-2521.html?tracking=6276281886467
  • 1 × FireBeetle ESP32 https://www.dfrobot.com/product-1590.html?tracking=6276281886467
  • 1 × 3.7 V Battery
  • 1 × Push Switch
  • 1 × Spray Paint(Silver, Black)
View all 6 components
  • 1
    Thank You NextPCB:
    This project is successfully completed because of the help and support from NextPCB. NextPCB is one of the most experienced PCB manufacturers in Global, has specialized in the PCB and assembly industry for over 15 years. Not only could NextPCB provide the most innovative printed circuit boards and assembly technologies in the highest quality standards, the fastest delivery turnaround as fast as 24 hours.
    Guys if you have a PCB project, please visit their website and get exciting discounts and coupons.
    Only 0$ for 5-10pcs PCB Prototypes:Nextpcb.com/pcbprototype
    4-layer PCB price reduction up to 40%: Nextpcb.com/4-layer-pcb
    Register and get $100 from NextPCB: Nextpcb.com/coupon
  • 2
    3D Printing
    • Download the Winter Soldier Mask stl Files.
    • Open the files in slicing software.
    • I have printed the objects with 0.2mm layer height, 20% infill and with tree support enabled.
    • After slicing 3D print the objects.
    • Remove the support material once prints are complete.
  • 3
    Painting
    For painting the mask I am using Silver and Black colored Paint Sprays.
    • First I painted the silver part.
    • After the silver part is dry I masked it and painted the black.
    • I am not using any sanding and smoothening techniques, but if you want then please go for it.
    • After the paint is dry glue both the mask objects as one single piece.
View all 10 instructions
