Received the new X1000 SoM, and ... Voilà ! (2022-09-07)
A project log for Linkia
Tiny Linux handheld with LoRa+WiFI+BT connectivity.
reimu-notmoeReimu NotMoe 10/21/2022 at 10:110 Comments
Original date: 2022-09-07
Related tweets: [1] [2] [3] [4] [5] [6]
TL;DR it's awesome! I'm so happy!
So I received the new X1000 SoM from JLCPCB. Surprisingly, the quality is good enough. They got everything right, including the 0201 passive components, 1612 crystals, XDFN-4 LDOs, and the 0.8mm BGA X1000. Nice.
And then, I can't wait to test if it works, so I used the jumper wires exactly like last time (lol). Smoke test passed, USB bootloader recognized, and firmware flashing works. Good. So then I built a new kernel image with the RTC clock workaround code removed. And... and !! The suspend-to-RAM FINALLY WORKS!!!! I used a USB multimeter to measure the power consumption, and it's ONLY 0.003W!!!! This means the X1000 itself can standby for more than a month on a 1000mAh Li-ion battery!!
Did you ever noticed that I actually soldered all SPI flashes upside down? It's embarrassing bruh ,-,
