Designed the PCB
06/05/2022 at 15:52 • 0 comments![]()
I have drawn the schematic on easyEDa online PCB design software. Then I designed a circular PCB for this project. Intentionally, I have used all the components through-hole type so that anyone including small children can also assemble it easily.
You can download the Gerber Files from PCBWay
Breadboard Testing
06/01/2022 at 10:28 • 0 comments![]()
Before finalizing the circuit, It is always a good idea to prototype the circuit on a breadboard. This lets you check to make sure that all of your components are working perfectly.
Make the circuit on your bread bard as per the schematic. The LED should not glow if the circuit is correct. To simulate the dark condition, cover the solar panel with your palm. Now the LED should glow.
To check the performance of the circuit, remove the LED and hook up the oscilloscope probes.
You will observe that the output is not a steady DC voltage rather it fluctuates rapidly. In my case, the frequency is around 184.5 kHz. The peak to peak voltage is nearly 7.28 V and the average value is around 1.0 to 1.20V.
Note: If you try to measure the voltage by a normal multimeter, it will show near to your battery voltage.Because your meters only measure the average value of a fluctuating voltage.
Open Green Energy
