• water pump and 4 solenoid valves can be controlled via MQTT e.g. Home Assistant
  • controller settings can be adjusted via web interface (available in German/English)
  • offers simple stand-alone scheduler to water plants once a day
  • ultrasonic sensor ensures minimal water level in reservoir
  • only one valve can be opened at a time to maximize pressure on each dripping branch
  • valves will switch off after preset time and then blocked to avoid accidental over-watering
  • writes events and sensor readings to log file in ESP32 flash including log rotation
  • creates a local access point for initial system setup or if no Wifi is available
  • OTA firmware updates
https://github.com/lrswss/esp32-irrigation-automation
