Upkie wheeled biped robot
A wheeled biped that can balance, go around and more. It is fully open source, both hardware and software.
Upkie is a fully open source, self-balancing wheeled biped robot. Its wheels allow it to balance continually. Its legs allow it to go off-road and negotiate uneven terrains. Upkie is designed to be made at home using tools and components ordered online (like mjbots actuators) and open source software maintained on GitHub. Robot motions are coordinated onboard by a Raspberry Pi.
To build Upkie from scratch, expect to spend around $3,000 in components, 60+ hours in 3D printing, and more hours of your work assembling and testing the beast. Community support is available on GitHub for both hardware and software of the robot.
upkie-blender.zip
Blender project of the fully assembled robot
Zip Archive - 41.07 MB - 09/27/2023 at 19:13
Download
upkie-stl.zip
STL model of the fully assembled robot
Zip Archive - 39.51 MB - 09/27/2023 at 19:13
Download
View all 9 components
  • Hollow leg, part 2
    Tast's Robotsan hour ago 0 comments
    This project log follows up to Hollow leg, part 1, where we redesigned Upkie's femur to route cables through. We now do the same for the tibia.
    Our goals are the same:
    1. Ensure that cables don't collide with the limb during motion.
    2. Keep a large range of motion for knee joint.
    Again, we switch to 3D printing for the tibia part, with a cable guiding hole going through it. The part is identical to the femur, but the heat-set insert holes are both on the same side this time:
    The ankle socket is redesigned as well with an hexagonal shape to better transmit torques:
    We also switched to cable sleeves rather than corrugated plastic tubing, as they slide more smoothly and bend less awkwardly:
    Assembled, the completed hollow leg looks like this:
    Let's see how this new leg fares on real robots! Details to build and assemble it are further documented in Upkie's build instructions.
  • Build instructions for new Upkie's
    Tast's Robots6 days ago 0 comments
    While building new copies of Upkie, we wrote full Build instructions for future travelers. These instructions cover all the steps from ordering to running a first balancing experiment:
    1. Getting started
    2. 3D printing
    3. Raspberry Pi setup
    4. Electronics testing
    5. Motion control software
    6. Assembly
    They go through intermediate stages like electronics assembly:
    With figures, so that new comers know (and old timers remember 😉) the orientation of each part:
    In the hope these instructions help spawn and maintain many Upkie's!
  • On GitHub: How to build Upkie from scratch?
    Tast's Robots04/01/2023 at 13:52 0 comments
    Build instructions on Hackaday.io work well for the outline, but as more copies of Upkie get built we wanted something that could scale nicely to include sub-steps, distribute related project files (3D printed parts, setup scripts, ...), and allow for discussions related to any given step.
    Introducing the upkie repository!
    • Instructions will be detailed step by step in the Wiki
    • Discussions allow anyone to comment/ask questions on any given step
    • 3D printing files and setup scripts are distributed in the companion build_upkie repository
    The wiki will be completed as we assemble another copy of the beast:
    Stay tuned!
  • Locomotion with a PS4 controller
    Tast's Robots11/13/2022 at 16:56 0 comments
    Upkie communicates with a regular PS4 controller. While this is not a key robotic feature, it is both cool (especially with kids 😃) and convenient to control the robot via Bluetooth. Before trying it out I was concerned about potential lags, or the Raspberry Pi loosing its connection to the controller, but the field summary after using it for months is: it just works. Here are my configuration notes, turned project log 😉
    The setup instructions are not specific to Upkie: we can connect a PS4 controller to any Raspberry Pi. Start with the Bluetooh command line:
    sudo bluetoothctl
    Enable the agent with the following four instructions:
    agent on
    discoverable on
    pairable on
    default-agent
    Then start scanning for devices. The terminal should start listing scan results with all the Bluetooth devices around you:
    scan on
    While the command tool is scanning, press and hold both the Share and PS buttons on your controller to switch it to pairing mode. Keep holding the buttons at the same time until it starts flashing white light. When it does, check the terminal output for a new line like this one:
    [NEW] Device AC:FD:93:14:25:D3 Wireless Controller
    Note down the controller MAC address (here AC:FD:93:14:25:D3). Check that the controller is still flashing and do:
    connect CONTROLLER_MAC_ADDRESS
    That should be it! If everything went well, you should see a "successful connection" message appear in the terminal, like so:
    [bluetooth]# connect AC:FD:93:FD:68:0F
    Attempting to connect to AC:FD:93:FD:68:0F
    [CHG] Device AC:FD:93:FD:68:0F Connected: yes
    [CHG] Device AC:FD:93:FD:68:0F UUIDs: 00001124-0000-1000-8000-00805f9b34fb
    [CHG] Device AC:FD:93:FD:68:0F UUIDs: 00001200-0000-1000-8000-00805f9b34fb
    [CHG] Device AC:FD:93:FD:68:0F ServicesResolved: yes
    [CHG] Device AC:FD:93:FD:68:0F Paired: yes
    Connection successful
    Finally, trust the controller so that it can connect after a reboot:
    [bluetooth]# trust AC:FD:93:FD:68:0F
    That's it! The controller should now appear as a regular Linux joystick device in /dev/input/js*. That's where the Joystick source in Vulp (Upkie's motion control software) will look for it. If it doesn't, perhaps you are running into the same reconnection issue I faced. Some follow-up troubleshooting notes in this discussion thread.
  • Hollow leg, part 1
    Tast's Robots08/10/2022 at 16:18 0 comments
    Sawing broomsticks to get Upkie up and running quickly was great at the beginning of the project, but it came with a drawback that came to light while manipulating the robot: a cable can get on the wrong side of a leg and get snapped away if the human manipulating it is not paying attention. Here is a bad instance on a shin:
    Pulling a cable hasn't happened yet while balancing, as the corrugated pipes that hold power and communication cables are quite stiff by themselves and tend to stay away from the legs, but it has happened for sure while sitting and raising the beast. So, today's update is about routing cables inside the legs. (This is part 1, we'll see about the lower leg in part 2.)
    Our goals are:
    1. Ensure that cables don't collide with the limbs during motion.
    2. Keep the same range of motion for hip joints.
    The idea is to 3D print a cable guide inside the hip, femur and knee parts. The femur thus becomes 3D printed (bye wood 😢).
    Here is a short video summary of the update:
    More details on the successive iterations:
    1. Hollow cylinder: this was a first guess. It would have worked with pressure screws like before, but then it occurred to me that squares and hexagons are much better shapes to transmit torque. (See for example this video from Scilabus on screw heads.)
    2. Hexagonal femur: testing torque transmission on mock parts with an outer hexagon and inner cylindrical cavity. To get a nice fit when assembling 3D printed parts, we can set either the femur outer diameter or hip inner diameter to be slightly smaller/larger.
    3. Hip with a hollow hexagon: going for a slightly larger hip inner diameter with a +0.2 mm margin on each edge. One mistake I did was to test the fit with small chunks of the inner shape, which may go through whereas the complete part won't (due to friction or jamming). Better print the whole (or at least a reasonable chunk of the) part to test this.
    4. Cylindrical femur with hex ends: the hexagonal shapes on both femur ends are exactly the right length to match the hips, and the femur is otherwise cylindrical. This facilitate assembly. Also, the inner cylinder guides the cable out the middle of the part to meet the knee servo connectors.
    5. Fixes to the hip: 3D printing iteration, getting all dimensions just right.
    6. Knee with a hollow inner hexagon: adapting the knee stator, following the same approach as the hip.
    At this stage, the leg assembly looks like this:
    One further nice thing to add are small rivulets inside the hollow cable guides to hold the corrugated pipe in place during motion:
    There are still several questions on the table that this design does not answer. How about turning the knee servo 180° to avoid the cable outlet in the middle of the femur? Also, can we get corrugated pipe that bends more smoothly?
    Note that we are keeping some length of cable above the hips to maintain the range of motion of the hip joint, in particular so that the robot can sit down and up properly. Eventually we can redesign the side chassis plates (blue in the picture above) to hold the cable better with a hole of the matching size (as opposed to a wide rectangular hole right now).
    Those points are left to future work 👷
  • Blowing off some CPU steam
    Tast's Robots06/11/2022 at 20:07 0 comments
    When running the Pink balancer agent on Upkie, the four CPU cores of the Raspberry Pi are used as follows:
    CPUID
    ProcessesThreadsUsage (%)
    0
    Spine (+ other system processes)
    Logger (+ other system threads)
    10 ± 5
    1SpineSpine loop
    10 ± 5
    2SpineCAN communications
    50 ± 20
    3AgentPython threads
    100
    On average over all cores, the ARM processor is only used at about 50% of its capacity, but that (or the fact that one core is used at 100% all the time) is enough to drive the CPU temperature up to a problematic level:
    (If you were wondering why Vulp has a CPU temperature observer, now you now 😉) The issue is that to protect itself the Raspberry Pi throttles all computations if its CPU temperature hits 80 °C, which for Upkie results mostly in skipped control frames (wheels apply their commanded velocities for too long ⇒ balancing degrades) and in the worst case triggers Vulp's safety of stopping actuators when no action is sent for more than 100 ms.
    Luckily it's not hard to cool down a Pi. Having a standing fan blow air at Upkie from the sides, where its wide "seal ears" are, does the job just fine. But the robot is not designed to stay near a fan, so let's give him an "earpiece" so that it carries its own fan:
    There is already a second male XT-30 connector on the pi3hat in Upkie's head, so we can order a 24 V DC fan from online retail, solder a female XT-30 connector to it, and just plug it to the power bus. In this update, the fan has the following properties:
    • Dimensions: 60x60x15 mm
    • Speed: 4700 rpm
    • Noise: 32 dBA
    • Power: 1.8 W
    • Flow: 44 m³/h
    The mount is a temporary adapter to connect to the existing right plate. Once we have settled on fan dimensions, we can redesign the plate so that it plugs into it directly:
    The fan is effective immediately. It brings down the CPU temperature to an equilibrium around 43 °C while the balancer is running full steam:
    Now the issue has become noise 😅 The fan's continuous 32 dBA relentlessly drill into the ears of neighboring humans, whose thoughts are inevitably driven to the next revision: smaller fan, less dBA!
  • February 2022 update
    Tast's Robots06/05/2022 at 11:10 0 comments
    Here comes a shot of the robot in its natural habitat: the living room!
    The main improvement in this update lies in the locomotion software, which performs smoother motions and allows the robot to crouch down further.
    There is also a hack, documented in the code as the non-minimum phase trick, to improve transitions from standing to driving with the simple PID balancer. Some pointers to dig further: this hack helps handle the non-minimum phase nature of balancing systems (the fact that to go one way one first needs to go "a little" the other way, like counter-steering in bikes) without going for full model predictive control.
    The small wheels (OD: 100 mm) on Upkie are nice because they are sleek, which fits well the assumption made by the PID balancer that controls the velocity of the contact points with the ground, unfortunately they are also a bit small which doesn't fit the ankle design so well. That, rather than knee torques, is actually what limits how much the robot can crouch before it starts scratching the hell out of the floor (^_^)
  • December 2021 update
    Tast's Robots06/05/2022 at 10:17 0 comments
    Let's start this log with a short tour of Upkie's very first "let's put things together" version:
    Cables are on their own, not attached to the skeleton (surely "skeleton" sounds better than "broomsticks" ;p) of the robot, and just float around thanks to the rigidity of the corrugated pipes that bundle them. This causes no problem for these first tests, but in future revisions we'll probably want to specify where they are and be sure Upkie can go through its full range of motion without pulling a cable out.
View all 8 project logs
  • 1
    Head over to the wiki
    Build instructions are in Upkie's wiki.
View all instructions
liang wrote 02/21/2023 at 12:02 point
hello,Can it achieve biped walking in the future?
Tast's Robots wrote 04/01/2023 at 14:08 point
That would be cool 😀 Especially to put the wheels on non-coplanar surfaces (like stairs, or just the two wheels on different slopes). We'd have to implement some form of lateral balancing, and check that the wheel BLDC motors have enough torque to lock the wheels in place as Upkie steps.
s_quintanar wrote 12/24/2022 at 19:33 point
Please add a head for vision and two arms so this wonderful robot you've created can be truly useful!
Tast's Robots wrote 02/19/2023 at 11:29 point
I've been experimenting a bit with Raspberry Pi camera modules, you can see one for instance at the end of https://www.youtube.com/shorts/ccFbJTHtiAQ. They are a viable option for vision, and the locomotion code leaves one CPU code mostly free for extra tasks, so that's one way to try visual processing with Upkie.
I haven't tried arms, but the pi3hat on Upkie has two unused CAN-FD ports (JC3 and JC4) that can be used to control up to one 3-DoF arm each. I'd be curious to see folks add arms to Upkie! I'd gladly help best I can with advice or SW support for that 😃
Peabody1929 wrote 11/13/2022 at 19:44 point
For hollow legs, how about ABS plastic pipe used for sprinkler systems?  It comes in 1/2", 3/4" and 1" diameter.
Tast's Robots wrote 02/03/2023 at 17:00 point
Could work! How would you rigidly attach the plastic pipe to the actuator's output shaft? (This is likely a basic question, I'm a mechanical newbie.)
When Upkie's legs were sawed broomsticks, I attached them to the output "horn" on the actuator shaft using pressure screws. They work fine at first, but as the robot moves and various efforts are exerted on the screws the connection deteriorates over date (the screw digs a hole in the wood that widens with effort).
Tom Nardi wrote 08/12/2022 at 01:29 point
This is a phenomenal project, very excited to see it develop.
Tast's Robots wrote 11/13/2022 at 17:14 point
Thanks! In November-December it will be mostly software updates (pink and upkie_locomotion packages) on GitHub: https://github.com/tasts-robots/ Then back to hardware with the hollow shins!
Tast's Robots wrote 04/01/2023 at 14:15 point
Following up: on the software side, upkie_locomotion is now on PyPI (pip install upkie_locomotion) and its API has leveled up so that we can run motion controllers in a few lines of Python. On the hardware side, the next project log will be on the hollow shins 😉
