Locomotion with a PS4 controller
A project log for Upkie wheeled biped robots
Wheeled biped robots that can balance, go around and more. Upkies are fully open source, both hardware and software.
upkie-zeroUpkie Zero 11/13/2022 at 16:560 Comments
Upkie communicates with a regular PS4 controller. While this is not a key robotic feature, it is both cool (especially with kids 😃) and convenient to control the robot via Bluetooth. Before trying it out I was concerned about potential lags, or the Raspberry Pi loosing its connection to the controller, but the field summary after using it for months is: it just works. Here are my configuration notes, turned project log 😉
The setup instructions are not specific to Upkie: we can connect a PS4 controller to any Raspberry Pi. Start with the Bluetooh command line:
sudo bluetoothctl
Enable the agent with the following four instructions:
agent on
discoverable on
pairable on
default-agent
Then start scanning for devices. The terminal should start listing scan results with all the Bluetooth devices around you:
scan on
While the command tool is scanning, press and hold both the Share and PS buttons on your controller to switch it to pairing mode. Keep holding the buttons at the same time until it starts flashing white light. When it does, check the terminal output for a new line like this one:
[NEW] Device AC:FD:93:14:25:D3 Wireless Controller
Note down the controller MAC address (here AC:FD:93:14:25:D3). Check that the controller is still flashing and do:
connect CONTROLLER_MAC_ADDRESS
That should be it! If everything went well, you should see a "successful connection" message appear in the terminal, like so:
[bluetooth]# connect AC:FD:93:FD:68:0F
Attempting to connect to AC:FD:93:FD:68:0F
[CHG] Device AC:FD:93:FD:68:0F Connected: yes
[CHG] Device AC:FD:93:FD:68:0F UUIDs: 00001124-0000-1000-8000-00805f9b34fb
[CHG] Device AC:FD:93:FD:68:0F UUIDs: 00001200-0000-1000-8000-00805f9b34fb
[CHG] Device AC:FD:93:FD:68:0F ServicesResolved: yes
[CHG] Device AC:FD:93:FD:68:0F Paired: yes
Connection successful
Finally, trust the controller so that it can connect after a reboot:
[bluetooth]# trust AC:FD:93:FD:68:0F
That's it! The controller should now appear as a regular Linux joystick device in /dev/input/js*. That's where the Joystick source in Vulp (Upkie's motion control software) will look for it. If it doesn't, perhaps you are running into the same reconnection issue I faced. Some follow-up troubleshooting notes in this discussion thread.
