Two Additions in one operation!
A project log for limited-code hacks/ideas
When you're running out of code-space... sometimes yah's gots to hack. Here are some ideas.
eric-hertzEric Hertz 04/12/2023 at 07:472 Comments
Maybe everyone knows this already, but I just thought of it for my first time...
Say you've got a 64bit processor, but you're working with two 32bit numbers... if they're stored in a single 64bit variable, and you're sure they won't overflow, you can do two additions simultaneously! Or 4 16bit additions, or 8 8bit!
So, what could this be used for? How often would that really be useful?
I dunno... a screen is significantly smaller than 65536x65536 pixels...
Presently I'm using an 8bitter, I have a function that I would like to return two TRUE/FALSE values. I want to keep running sums of those two values from each time it's called.
//Returns:
//0x01 if button A pressed
//0x10 if button B pressed
//0x11 if both are pressed
uint8_t getButtons(void);
main()
   uint8_t countsCombined=0;
   for(i=0; i<15; i++)
      countsCombined+=getButtons();
   printf("A presses = %d\n"
          "B presses = %d\n",
          countsCombined&0x0f,
          countsCombined>>4);
But, holy moly, this seems a little cheesy on an 8bitter, but just think what could be done on a 16bitter, or 64bitter!
Maybe you're designing PONG on a 16bit computer in a 256x256 window, the ball moves two pixels up, one left:
//Upper byte is X, lower byte is Y
uint16_t ballPosition = 0x0000;
uint16_t ballStep = 0x0102;
while(wallNotHit)
   ballPosition += ballStep;
Dylan Brophy wrote 04/12/2023 at 14:43 point
We need a compiler that automatically does these operations - I bet the code would be faster too!
Eric Hertz wrote 04/12/2023 at 20:55 point
Exactly! maybe they already do? 'Cause I never really could imagine it's really /that/ often software needs 64bit integers otherwise, aside from addressing.
