I stumbled over a similar project in a German Maker Newspaper.
This project uses ducky scripts stored on a SD card for storing complex stuff. Please see the Code Reference of Ducky script here
The concept behind this is explained here. For me this sounds awesome and I have everything for it on Board.
With the ESP32-S I can even use the Board as a MassStorage Device. This enables changing Scirpts directly on the Keyboard on the go like using an USB Stick.
Additionally I have a Micro SD Card Holder ready and good to Go.
More Info about Ducky Script:
Now I am thing if I should add this option to the code as well... Stay Tuned
