8 key macropad
A project log for DIY input devices
A selection of DIY input devices i made over the years
yannick-gigawipfYannick (Gigawipf) 06/09/2022 at 06:530 Comments
This was my first DIY input device but still in use as a stream and macro controller
Its based around a maxkeyboard acrylic switch tester (not sure if its still sold...) and an arduino micro.
Later i have added a 3d printed case to make it a bit cleaner.
Files are found in the files section if you really want to make this. The arduino code may be helpful for other projects.
