Why the world needs a solar LCD creature
Designing Klara has been a balancing act, trying to reconcile my desire to repurpose everyday parts with the practical limitations of technology and struggling supply chains :)
Unsealing the inside. So much of technology around us, especially consumer electronics, is pretending to be something virtual that seals its inside in a shiny white enclosure. But technology, with all its messy and often chaotic detail, can be beautiful. Let's turn electronics into an aesthetic object. Let's put the circuitry itself on display!
Repurposing parts. The 4-digit LCD is one of the most banal objects around us. Let's give it a new purpose that's not just about showing the current time or temperature! It has 32 independent segments -- that should be enough to put on an entertaining show. Similarly, a mass-produced temperature sensor used in cars can find new meaning in an indoor solar sculpture.
Solar autonomy. A little machine that has no moving parts that wear out can, in theory, work indefinitely, as long as it receives sunlight. That makes it a little like a biological being, forever absorbing sunshine to defy entropy.
Capricious reactions. A thermometer reacts to changing temperature, but it's still a pretty dumb thing. In contrast, a programmed creature can go beyond sensing its environment and also react to it in interesting ways. Animations slow down and freeze as its energy declines. Every morning when it wakes up it can choose a different, unpredictable set of shapes and animations to show that day.
Minimalism. A solar circuit needs to conserve power, which by itself makes it an excercise in minimalism. How much can we squeeze out of a tiny computer with only 128 bytes of RAM? What is the most interesting show the creature can put on using its simple LCD display?
Transparency. Consumer products are not only physically sealed to hide their internals; they also disguise the details of their inner state. This creature reports its parameters directly. It doesn't say its power is at X percent; it shows its actual voltage level, and reports the temperature it has measured. And it doesn't only showcase its circuitry. All its designs, schematics and code is public, so anyone can build it or derive a different creature from it.
Sources of inspiration
- BEAM circuits (from biology, electronics, aesthetics and mechanics). Wonderfully detailed on Solarbotics and SMFR, also with a lot of useful schematics.
- Mohit Bhoite's circuit sculptures
- Joey Castillo's Sensor Watch
Technical design
This section is work in progress; it will be updated as I make progress with the build. Do check out the project logs for incremental updates!
There will be details here about:
- Klara's circuitry
- Software
- PCB design
- The laser-cut sculpture frame
- Final assembly
