CT system Revamp
The most probable failure to decommissioned a system is Image Processing Unit Hardware. Here a way to Rescue it, using Open Source solutions
Had you ever faced in your embebed system a software crash?
Well, as a Field Service Engineer, that is a common scenario. From Sudden power shutdown, mishandling and corrupted data, the result is the same: system does not work. the easy/quick way to solve it (and most recomendable), is delete HDD, then reload whole package.
All systems comes with input devices; past century came with Floppy Drives (8 inch and 3.5 inches). machines from 2000 comes with CD/DVD units. Newer systems come with DVD Ram. When system is new, the reload process is smooth. as time goes on, units fail to read, disk gets data loss, bad sectors, etc. sometimes you need to do whole reload 2-3 times, until success.
Eventually, you will have a 100% working hardware, but a system unusable, because of software. at this point, the solution is purchase new system. Since the price of this kind of apparatus starts from couple hundred thousand dollars (and beyond), at the villages and remotes areas can be prohibitive.
All starts with the background photo posted here... that was in 2017. the picture shows a discarted Gantry from CT system, at junkyard. in that moment, i was sad for the loss. i repair/fixed many systems like this.
  • Pentium Inside
    proyectosyprototipos09/29/2022 at 15:57 0 comments
    In computer enviroment, is difficult to say  what is worst.... get parts/resources, or putting them in working condition.....
    I found a old Pentium tower with the ISA bus nedded to use the Digitizer board
    A little upgrade done, is add a Fan to CPU module.
    after cleaning and testing the power supply, CD unit, Memory, etc... it is running
    Now is possible start to install the software: the digitizer software runs on D.O.S. then i need how to move the files later into a USB Stick.
    here a picture of the digitizer sofware
    Here the programming is  typing automated macros/scripts, to capture the Xray profiles, prior to reconstruction.
  • A small Detour
    proyectosyprototipos09/29/2022 at 15:40 0 comments
    Well.... some time without posting here. When things needs detail, speed goes down.
    I had the chance to support a Dicom Viewer Station, implemented with an Imac PC.
    Despite the commercial grade, the Retina Display has good enough specs near to Medical grade monitors, with a fraction of the cost. The picture shows the GUI from this Dicom Viewer to compare with the posted photo of the Skull; this bring a signal that is a good choice to use it.
  • Reuse for Revamp
    proyectosyprototipos06/15/2022 at 20:14 0 comments
    The 3D Slicer is perfect to show the output images for the doctor´s diagnostic. However, there is a couple of things:
    1) 3D slicer works with 2D images. It can use plenty of file formats, but again, 2D images.
    2) CT systems does not produce images, it delivers Projections.
    In this scenario, i need take the data collected from Gantry ( Detector), and translate to 2D images for use in 3D Slicer.  To do the first part, i will Reuse this board:
    This is an old 8 bit Frame Grabber that i got, and i had used into another past projects. As you can see, this board has a ISA BUS.  This is itself a challenge, because i need to put in working condition the board to capture the projections.
  • Taking choices
    proyectosyprototipos06/15/2022 at 16:53 0 comments
    After a Tons of reading, testing and evaluating the Open Source options, i found a perfect tool for this Project (conversion of 2D images into 3D volume, then slice it arbitrary). This is exactly what a doctor does analizing the patient´s anatomy. The software with the GUI closest  to market systems is 3D SLICER (www.slicer.org)
    This photo shows how it works, using a DataSet available for download with the software.
    keeping the Open Source soul, the system is running on UBUNTU.
  • Get the whole picture
    proyectosyprototipos06/15/2022 at 15:50 0 comments
    In the every day work, i put all my enthusiam and effort to recognize what is the fault in a broken system, from the Field Service point of view. That is, have clear what means every error code, and the countermeasures to fix it ASAP. I never realized (nor had time to think about), what is happenning under the hood.
    Then, the pandemic´s lockdown came.....
    In my case, i had a lot of free time to invest in research and web surfing, to learn, understand, and figure out how to do my idea. There is a lot of useful information out there. if you want read, then try this entries at google:
    - Computed Tomography
    - CT reconstruction
    - FDK reconstruction
    - Inverse Radon transform
    - Tomographic Reconstruction Wiki
    Youtube has nice presentations too, and if you like advanced Maths, the ReseachGate WebPage has very interesting papers/lecturers of academic rigor.
  • Where to start
    proyectosyprototipos06/11/2022 at 00:02 0 comments
    At this point, is clear that system comprises three big modules:
    1) Xray generation
    2) Projection Acquisition
    3) Data Processing
    Since this endeavor is revamp a system, the idea is to replace/update only 3,) or perhaps 2) and 3). Of course, nobody lets modify a working system to do Tests or Proof of concept. Then i need to figure out how to do it.
    Here is a system that uses as Data Processing a couple of SGI´s computers: The Left is a Octane computer, the right side is an O2 system, without plastic covers. SGI computers were used in the commercial enviroment by graphic designers and audiovisual producers. this is my start point to find open source software to do the job.
  • The Basics III
    proyectosyprototipos06/10/2022 at 23:01 0 comments
    With Data Collected inside console, then you need processing it to convert to perpendicular views, that is the images the Doctor uses to evaluate patient condition.
    The video shows how it works: The relative movement between couple Tube-Detector and patient (Lemon), brings a series of photos taken around him (it). That photos are called Projections, and a set of Projections are called Sinogram (in this example, the Sinogram is the video spinning the Lemon). After a mathematical processing of the projections, you get the reconstructed image ( the Lemon Slice). The reconstructed image let you see the internal features of the structure. For example, in a Head exam, you can see how is the brain, without open the skull, even touch it!.
  • the Basics II
    proyectosyprototipos06/10/2022 at 21:38 0 comments
    here three Console generations:
    Left: System from early 90s
    Center: System from late 90s
    Right: System from middle 2010
    In the earlier systems, all the electronics was Tailor made; CPUs, memory boards, Interface boards, etc, were designed for the specific model. However, since the computational power of modern PCs is amazing, manufacturers start to use it in their systems. in the right photo we can see a Dell Precision T5400 tower.
    The three machines does same thing: axial slices from scanned patient.... the difference? the older takes 3-5 seconds to do a single slice (image), while the newer build 16 images every single second!.....well, there is much faster systems, doing bigger amounts of images in a fraction of single second.
  • The Basics I
    proyectosyprototipos06/10/2022 at 20:56 0 comments
    In this photo, a system still installed, being serviced. The main parts of the gantry, are the Xray source (the tube), and the Xray detectors array. The Tube is the gold part located almost 3 O´clock (well, there is a replacement inside the blue box at bottom); The Detector array is oposite side (the semicircular black thing). To be scanned, the patient is lying down between tube and detector. When system acquire data, the couple Tube-Detector rotates around the patient, with the tube emitting Xray, and the Detector receiving the images. The collected Data is sent to Image Processing Unit (operator console), for processing/computing job.
View all 9 project logs
Carlos Noguera wrote 09/29/2022 at 18:38 point
What format does the gantry/detector produce it's projections in, and also what are the physical connections from the gantry/detector that you interface to the frame grabber?
Very interesting project! I wish you success - it's always admirable to see someone trying to repair/reuse equipment.
proyectosyprototipos wrote 10/03/2022 at 14:23 point
Hello Carlos. Detector delivers an Analog signal that is A/D converted, then serialized to deliver. depending of manufacturer, model and age, is the bit-wide.
