A small Detour
A project log for CT system Revamp
The most probable failure to decommissioned a system is Image Processing Unit Hardware. Here a way to Rescue it, using Open Source solutions
proyectosyprototiposproyectosyprototipos 09/29/2022 at 15:400 Comments
Well.... some time without posting here. When things needs detail, speed goes down.
I had the chance to support a Dicom Viewer Station, implemented with an Imac PC.
Despite the commercial grade, the Retina Display has good enough specs near to Medical grade monitors, with a fraction of the cost. The picture shows the GUI from this Dicom Viewer to compare with the posted photo of the Skull; this bring a signal that is a good choice to use it.
