network bandwidth an issue
A project log for networked RTL-SDR server
a wifi-based RTL-SDR receiver to cover 1 to 500 MHz
worsthorseworsthorse 11/26/2016 at 16:570 Comments
when the dongle is supplying data over wifi, the SDR seems to stall two or three times a minute. i don't know if this is a buffering problem on the server or client side or a wifi bandwidth problem. i am guessing it is the wifi because my network has a lot of devices on it. i am going to configure the router as an access point on its own network (and a different wifi channel) and see what that does. more to follow...
