Update!
The X-PC now works with any donor laptop. I've redesigned it parametrically using FreeCAD. Check out the logs for more info.
The First X-PC
The motherboards were in good working order as were the screens, so I started to disassemble one.
Once all the parts were removed, I connected a USB keyboard and powered it up and everything worked!
I then set about designing a new housing to hold all of the bits.
There were a few things I wanted to achieve with this design.
1. Attached USB keyboard and mouse - cheap to replace if they get broken and fixed to the computer so they can't go missing. 2. Attached internal power supply unit - so It can't go missing and less chance of breaking. 3. Restricted access to the computer ports and switches - The students tend to fiddle with everything on the computers especially the WiFi switch, and plug things in where they're not supposed to be plugged in. 4. Portability, a carry handle and the ability to store the keyboard and mouse. 5. To be manufactured from acrylic using a Laser cutter. 5. Good looks!
First I started to design a mount for the motherboard. The tricky bit here was getting all of the mounting holes to line up. I used a piece of transparent acrylic to trace the outline of the motherboard and any protruding parts. I then marked and measured the mounting holes that I wanted to use. I laser cut a prototype out of 3mm MDF to test the positions. It took a few attempts to get this right.
After a few more iterations I'd made a panel with a bezel to hold the screen and mounting holes for the motherboard to attach to the back.
Next I started to design the frame to hold everything together. I toyed with the idea of using a hinge to adjust the angle of the screen a bit like as MS Surface (possibly reusing the original laptop screen hinges) but soon moved away from this as I wanted to keep it simple and have less chance of parts breaking.
I started looking at an A-frame design, this seemed like a good solution as it has an angled front for the screen a wide base for stability and a space to store the keyboard. I also liked the idea of using a living hinge at the top to add a curve to the normally angular looks of laser cut designs. Here's my prototype after a few iterations:
And my final version in acrylic:
Here's an assembled screen and motherboard mount with a clear acrylic back panel for protection. This whole unit slides up inside the front of the A-frame and is held in place with a couple of screws.
Some pictures of an assembled unit, showing keyboard storage, internal PSU and the USB and headphone socket (from a car dashboard mounting kit).
The power switch PCB is mounted at the bottom of the front panel, I 3D printed a button in clear PLA so it would light up when switched on.
In the classroom:
What's next ? I've been given about thirty more old laptops. So I'll start converting these into more X-PC's, unfortunately they have slightly different motherboards so I'll need to modify the design to make them fit. I'm also planning to do a Raspberry Pi version (obviously!).
Neil Lambeth
Awesome project!
This seems like a great solution for hardware that can't be brought back to original shape.
+1 brownie point for installing Linux on them! Exposing kids to Linux in itself is a STEM bonus.
I wish they were doing stuff like that at my kids school.
Thank you for sharing this project.
