X-PC Files For Laser Cutting
A project log for The X-PC. Hackaday Prize 2022 Entry
Old laptops reconfigured into new computers for schools.
Neil LambethNeil Lambeth 06/12/2022 at 11:040 Comments
I've added the FreeCAD 3D Parametric model to the Files section.
From this you can generate the 2D files for lasercutting.
If you are using Techsoft 2D Design (as used in UK schools) export the file from FreeCAD as a.dxf. Then in Techsoft 2D Deign select Import from the File menu, then change the units to mm in the DXF Import setup.
Licence: Attribution-NonCommercial-ShareAlike 4.0 International (CC BY-NC-SA 4.0)
