The orders have arrived. 3 remotes and 2 charging bases. The most beat-up remote was taken apart to inspect. While reuse of all the existing electronics would maximize recycled content, the effort to re-design will be a lot less than effort to re-engineer the internals.
The waveshare 2.0 inch TFT screen is a perfect size for replacement. Need to find a way to remove from the carrier PCB without damage.
The existing remote looks to have used EL tape for the keypad back lights. This looks like a good opportunity for reverse mount LEDs.
ESP32 will be used for replacement processor with a MSP430 dedicated for keypad matrix scanning. Time to start on a PCB to test button, LED, and screen fitment in the case.
mulcmu
