Alpha3 PCB has been finished and sent off for fabrication. All of the power management, battery charging, and IR parts are on a remote shaped PCB to test the fitup. I started routing some of the button matrix and ended up getting everything routed on a 2 layer PCB. Lots of vias and room for some improvements. Maybe 4 layer pcb can be avoided.
mulcmu
