How to make your playlist in an easy way
A project log for Slot-In Record Player with Arduino rfid & mp3
Transform an old "slot-in record player": make a magical mp3 player with the help of RFID reader and tags
jean-noelJean Noel 07/20/2022 at 10:010 Comments
You'll need:
For the mp3 files, you can find the music on youtube and use MediaHuman YouTube to MP3 Converter for instance
Now, for each element of your playlist follow those steps:
  1. stick the RFID tag at the center of the vinyl record
  2. put the vinyl record back into his cover
  3. insert it into the slot-in player
  4. the tag's ID will be displayed on the LCD screen, take note of this ID (eight characters)
  5. rename the mp3 file on the SD card with the ID, don't change the .mp3 extension
